10th Mar 2012, 11:56 am | #1 |
How can I improve my aerial reception?
Hi All
I live in the back of beyond on the lleyn peninsular in N.Wales and all I seem to be able to receive on my radios are a couple of Irish stations and Radio 4. plus a few foreign stations. I currently have an external aerial made of 7 strand insulated copper wire,about 20ft. long strung horizontally across two buildings about 15ft. high. It has clear sky out to the Irish sea but hills and the Snowdonia mountain range in most other directions. Can anybody suggest anything I can do to improve reception (apart from moving back to civilisation) Many Thanks Alan |
10th Mar 2012, 1:09 pm | #2 |
Re: How can I improve my aerial reception?
A Welbrook loop http://www.wellbrook.uk.com/, bloomin brilliant.
10th Mar 2012, 1:26 pm | #3 |
What sort of radio's Alan? I assume you are talking vintage radio's here. I've a couple of Wellbrook loops as well and they are fantastic antennas, but really are better suited for use with a 'proper' communications receiver. They wouldn't be my first choice for a vintage valve radio.
Regards Last edited by Robert Darwent; 10th Mar 2012 at 1:36 pm. |
10th Mar 2012, 1:45 pm | #4 |
I am talking vintage sets
I've looked at the Wellbrook site,they look a bit expensive. I was hoping for something a bit more DIY |
10th Mar 2012, 2:25 pm | #5 |
For a wire aerial, the more wire the better, and the higher the better. Far better for it to be outdoors than in the loft. Important for the aerial to be "opened out" in the space available rather than bunched up in one small corner of the available space. Chris.
10th Mar 2012, 3:00 pm | #6 | |
10th Mar 2012, 5:48 pm | #7 | ||
Regards |
10th Mar 2012, 6:07 pm | #8 |
For LW and daytime MW reception antenna height is the main thing. By 'height' I mean the total vertical distance between your earth connection (which may be your mains earth near your meter, or a separate RF earth) and the highest point in your aerial. Second is the amount of wire you can get at the highest point, as this acts as a capacitive top hat. This assumes that noise is not too much of a problem; I guess in your case much of any noise will be from devices in your own house. If you can't get enough height, or noise is a problem, then a loop will be better. There are DIY designs.
10th Mar 2012, 7:01 pm | #9 |
Alan - when you say that you have the horizontal portion of your aerial "strung across two buildings", do you actually mean "between two buildings"? I say this since in the latter case, there should then be plenty of 'free space' around the horizontal portion. If, however, the former case applies, and the horizontal section is lying on top of and in contact with the two buildings (as in "across" them), that won't do at all!
Al. |
10th Mar 2012, 7:04 pm | #10 |
How about building a squarial loop?I remember many years ago the construction details in Practical Wireless.
It is two 5ft lengths of wood arranged in an X shape. At the 4 corners you attach V shaped pieces of hardboard or plywood with 7 cut slots 1/2 inch apart. You then wind around it seven turns of thin wire (22gauge or similar). The two ends of the wire are taken to the centre of the "X" and across it is soldered a 30-350pF variable capacitor. (Found in most old radios). A insulated single loop is then wound on the 3rd winding and taken to the aerial terminal of the radio The other going to the earth terminal. The loop is very directional and is tuned to the required Medium wave frequency by the variable capacitor. I found when using transistor radios I did not need the extra single loop the radio just needed to be put next to the seven wires. You could mount this in a loft. Tune to the correct frequency then bring the single loop wire down to the radio in the house. Hope this helps. I built one in the earlier 1970's and it does work! |
10th Mar 2012, 9:47 pm | #11 | |
10th Mar 2012, 10:49 pm | #12 |
You've misunderstood my reply. I was referring specifically to Alan's (Dickiebird) situation in his original post.
Like I said earlier, I've a couple of Wellbrook loops myself, they are well worth the money IMHO. Regards Last edited by Robert Darwent; 10th Mar 2012 at 10:57 pm. |
10th Mar 2012, 11:13 pm | #13 |
