10th Jun 2018, 5:45 pm | #1 |
W.G. Pye signal generator
I found a W.G. Pye signal generator, it is from around 1949 and i have searched all over the internet to find it, but found nothing...
The device is in the pictures bellow. |
10th Jun 2018, 7:10 pm | #2 |
Re: W.G. pye?
The "line" and "frame" settings imply that it was designed for TV use; the coaxial output-socket is a 'Pye-plug' which dates it to the era around WWII.
Pye made loads of RF "stuff" from the 1930s through the 1980s. Is there any other model-number or similar on the rear/ |
10th Jun 2018, 7:13 pm | #3 |
Re: W.G. pye?
Those bakelite paignton knobs were fitted to a wide variety of equipment so a replacement shouldn't be too hard to find. Note the main control increases when turned anti-clock!
10th Jun 2018, 7:27 pm | #4 |
Re: W.G. pye?
Pye Signal Generator Type 940226:
https://www.americanradiohistory.com...l generator%22 For a permanent ref: mag page 442, WW Nov. 1949: https://www.americanradiohistory.com...ld-1949-11.pdf Lawrence. Last edited by ms660; 10th Jun 2018 at 7:48 pm. Reason: additions |
10th Jun 2018, 9:50 pm | #5 |
Thank you for the info. I was given it today and I want to know more about the history of it and it's quite an interesting looking machine and has a mains input at the back.
The device also has a "mains voltage adjustment" terminal with two pins on the back, as shown in the photo below: |
11th Jun 2018, 12:33 am | #6 |
Re: W.G. Pye signal generator
That looks like a mains connector.
12th Jun 2018, 12:01 am | #7 |
I expect that it means there is some sort of mains voltage selection (link or switch) accessible underneath the panel once the six screws have been undone- it makes sure (or at least less likely....) that it won't be meddled with the mains lead connected.
12th Jun 2018, 1:31 pm | #8 | |
https://www.vintage-radio.net/forum/...d.php?t=118902 |
15th Jun 2018, 10:33 pm | #9 |
Out of interest, would this thing contain valves (vacuum tubes)
16th Jun 2018, 12:25 am | #10 |
Yes, transistors were still in the laboratory back then. Two, possibly three valves.
