Reply
Old 22nd Jul 2025, 10:05 pm   #1
TacoTuesday1839
Default Sony kv-9000ub Restoration
Hi, I’m working on a Sony kv-9000ub with power but no picture. I have minimal experience working on crt’s but I have experience in audio equipment. I’m unsure where to begin testing although I have tried a replacement horizontal output transistor as it was getting hot but this has made no change. I can tune in a channel with clear audio, you can hear high voltage and the crt is glowing. The only brief life I got out of the screen was two lines that flashed on the screen when pressing the degauss button on the rear upon first power up.
TacoTuesday1839 is offline   Reply With Quote
Old 23rd Jul 2025, 8:45 am   #2
ronbryan
Default Re: Sony kv-9000ub Restoration
For the HOT that is running hot, you could try changing C520 1uF 50V which decouples the collector supply to the horizontal driver transistor Q502 and associated horizontal driver transformer.
Ron
ronbryan is offline   Reply With Quote
Old 23rd Jul 2025, 10:14 am   #3
Welsh Anorak
Welsh Anorak's Avatar
Hello and welcome to the forum.
How hot is hot? Transistors in this position do run quite warm, certainly compared to ones you might be more familiar with. If it's unusually hot then of course Ron's advice is good - in fact changing this capacitor would be a good idea anyway.
You say you can hear the EHT and you get a brief display, so the HOT stage is working to some extent.
I'd have a look at the CRT base voltages to see if the cathodes are biased off or the G2 is missing or low. I'd expect between 100 and 140v on the cathodes, and 400-700v on the G2 pins.
A circuit diagram is invaluable here. If you don't have one you can download one from Elektrotanya.
Glyn
Welsh Anorak is offline   Reply With Quote
Old 25th Jul 2025, 8:54 am   #4
Dr-Watts
Dr-Watts's Avatar
Sounds like a typical case of no frame to me and the set had gone into protection mode and blanked the picture to save screen burn
Do you have the scope to be a TV repair man ?
Dr-Watts is offline   Reply With Quote
Old 29th Jul 2025, 1:55 am   #5
TacoTuesday1839
I have now replaced this capacitor, the horizontal transistor still seems to be acting the same and I have observed no change on screen, however in regards to the temperature it is too hot to touch for too long while powered up.
Reply
