28th Aug 2014, 10:09 pm | #1 |
Homemade Microphones
When I was a young lad (many moons ago ) I used to make carbon Mics by filling a miniature polish tin (Betterware ?) with filed down dust from a battery carbon centre electrode .
The top was covered with tin foil forming the mouth piece.A wire insulated from the tin was poked through a hole in the base of the tin into the carbon dust.It worked quite well wired with a 4.5 v light battery in series with a home made receiver which was made winding a coil around a magnet and a baked tin lid as the earpiece! Last edited by AC/HL; 29th Aug 2014 at 2:57 am. Reason: Thread split |
30th Aug 2014, 12:21 am | #2 |
Re: Homemade Microphones
This is a good illustration of just how basic you can make something and still have it work! How did you arrive at the idea?
Regards, Paul
...No, it's not supposed to pick up the World Service, it's not a radio! |
30th Aug 2014, 9:19 am | #3 |
I made a couple of condenser mics many years back, with an insulated back plate having a thin stainless steel membrane stretched over this with a small air gap. A built in pre-amp using an ECC81 in cascode gave a very good performance. The extreme HF response was a bit poor though, probably due to the thickness of the membrane.
30th Aug 2014, 6:03 pm | #4 |
When I were a lad.....
My father made a microphone based on some pictures in a BOP annual from the 1890s in a series on how to make your own telephones (literally from the sort of materials that were available to an enthusiastic youngster then). Dad's version involved the carbon rod from a U2 and a couple of dynamo brushes (he was a mechanic). A hole was drilled in each brush and the ends of the rod turned down to be a loose fit between the two brushes- the shoulders on the rod stopped it from falling out. The brushes were fixed to a piece of wood by passing their tails through suitable holes and retaining them with choc block terminals. In series with a 3V battery and a headphone set it worked quite well!
30th Aug 2014, 6:51 pm | #5 |
Hi Paul,
It was so long ago I can't remember how I came up with the idea.Possibly at the age of 10 ish it was driven by lack of funds! Cheers,Pete |
31st Aug 2014, 10:52 am | #6 |
I remember building a carbon granule MIC back when i was 9 years old and had seen it done on the TV show The secrete life of mashies. it used a plastic coffee jar lid with two pieces of silver foil stuck to the base. this was filled with carbon granules and a plastic disk put on top to act as the diaphragm. it worked quite well connected to a 6v lantern battery and an old HiFi speaker
Jay
The light at the end of the tunnel is probably the headlight of an oncoming train |
1st Sep 2014, 5:30 pm | #7 |
One that I made back in 1963 consisted of an inverted cigar box with two razor blades stuck in so that they were parallel to each other. A carbon rod, ex battery, was laid across the tops of the blades and wires and a series battery attached to them. It worked a treat.
