Old 30th Sep 2017, 11:33 am   #1
ms660
ms660's Avatar
Default Load Line Exercise...How to ?
Just an exercise, hypothetical schematic, triode amplifier and a pentode amplifier, both valve types are known, both have resistors for their anode loads, both use cathode bias, resistor values are known as is the HT supply voltage, no other voltages given on the schematic.
Need to find the operating point as designed for both valves, done the triode using anode and cathode load lines.
Can't get anything to tally when trying to do the pentode...why?
Lawrence.
ms660 is offline
Old 30th Sep 2017, 12:24 pm   #2
ukvrshaun
Default Re: Load Line Exercise...How to ?
Usually the Anode Current v. Anode Voltage plot for a Pentode is for a particular Vg2 voltage. For other values of Vg2, the Vg1 lines will be either stretched or concertinaed in the vertical direction. You can guess the appropriate Vg1 lines for a particular Vg2 using the Anode Current v. Control Grid (Vg1) plot (Vg2 is the parameter).
See this article which explains how to do that:
http://valvewizard.co.uk/pentode.html
Then for the design intended value of Vg2, the operating point can be guessed from the load line, as per the triode method. It will probably require iteration to get to the design values.
You could also do an LTspice simulation using the resistor and HT values you have. The 'correct' voltages and currents will 'fall out' of that simulation and will thus given the pentode operating point.
Shaun
ukvrshaun is offline
Old 30th Sep 2017, 12:27 pm   #3
ms660
ms660's Avatar
Looked at that, can't get a cathode load line to tally up....Why?
Lawrence.
ms660 is offline
Old 30th Sep 2017, 12:46 pm   #4
ukvrshaun
Should work, assuming the data sheet is correct and the values on the schematic are correct! The Vg1 lines do move up or down quite a lot for different values of Vg2.
I can probably LTspice it for you if you let me know the details...
Old 30th Sep 2017, 12:55 pm   #5
Diabolical Artificer
Diabolical Artificer's Avatar
What pentode Lawrence? One other thing occurs somewhere at the back of my noggin, when drawing a cathode LL the mu of the valve has to taken into account. Also that you have to include the screen grid current in your calculations. These effect the slope of the line. Have you looked at Radio Designers?
Andy.
Old 30th Sep 2017, 1:14 pm   #6
ms660
ms660's Avatar
I still can't get it to work for a pentode...intersection of anode and cathode load line...can't get the cathode load line to work out.
Eg:
ECC83, Ia/Va characteristics, I can do the anode load line for a given value of anode load resistor and a cathode load line for a given value of cathode resistor, where the two intersect gives the operating point, no problem.
EF86, Ia/Va characteristics, I can do the anode load line for a given value of anode load resistance, cathode load line is no go, nothing makes sense, eg: in your linked example (valve wizard) try marking the point on the curves for the 680 ohm cathode resistor on the -ve 0.5v curve then the -ve 2.5v curve as the reference points for drawing a cathode load line, I can't get it to work so what's going on? It works for the triode example, everything fits no problem.
Maybe my method is wrong?
Lawrence.
ms660 is offline
Old 30th Sep 2017, 1:42 pm   #7
ms660
ms660's Avatar
Got it..wood for the trees...constant current.
But.....still, how can a pentode cathode load line be plotted using the manufactures valve curves?
Lawrence.
ms660 is offline
Old 30th Sep 2017, 2:11 pm   #8
ukvrshaun
Different Vg1 lines for different Vg2 (300V, 250V, 200V) for a KT88 pentode with same load line.
Different Vg operating points (-26V, -18V, -12V) for the same anode voltage (300V)...
ID:	150097   Click image for larger version
ID:	150098   Click image for larger version
