24th Sep 2017, 11:02 pm | #1 |
Adhesive for glass?
Not sure if this thread is in the correct section: mods - please relocate if necessary; thank you.
I am aware that adhesive for glass (as in joining two pieces of glass, so that they are back as one piece again) is available. But will 'superglue' be effective? And is so-called 'glass adhesive' any good, anyway? Al. |
25th Sep 2017, 12:48 am | #2 |
Re: Adhesive for glass?
Found the Loctite superglue for glass very good, it has been holding together a broken drink glass for several years now(only repaired because it had an award inscription on it).
Sometimes if you get the two pieces at the right angle the repair becomes almost invisible..but being a superglue you have not got a lot of time to mess around. |
25th Sep 2017, 2:39 am | #3 |
yep, I've stuck broken glass together with no-name superglue. As always, getting the surfaces really clean is critical.
B
25th Sep 2017, 8:19 am | #4 |
Have a look here: https://www.vintage-radio.net/forum/...d.php?t=124143
25th Sep 2017, 10:45 am | #5 |
The best thing I have ever find for sticking glass is silicon rubber, I remember that in the '50's Dowl Corning silicon was used for making fish tanks and the glass would break before the joint went.
Peter |
25th Sep 2017, 11:06 am | #6 |
I also have used Locktite glass bond successfully on glass to glass joints. I think this adhesive needs UV light to cure the glue.
Ron |
25th Sep 2017, 11:23 am | #7 |
Thanks for your replies: I will attempt a repair with 'Superglue' - and then let you know the result.
Al. |
26th Sep 2017, 12:17 pm | #8 |
Yes, that worked. Only question is this: how long will it last before the adhesive 'gives up' ?
Al. |
26th Sep 2017, 12:38 pm | #9 |
A glass lamp shade I mended using the original Loctite glass bond is still perfectly sound after more than a decade, although from the posts in the earlier thread identified in #4 it seems that the current stuff has a different formulation.
26th Sep 2017, 1:02 pm | #10 | |
B
26th Sep 2017, 1:24 pm | #11 |
Amendment to my post #8. I've just carefully picked up the glass panel - and the glued joint failed! And yes, I did thoroughly clean the two mating surfaces first.
So time to try Loctite glass bond. Al. |
26th Sep 2017, 3:42 pm | #12 |
Superglue does degrade (very slowly) in water, so leave the broken repair in water for a week before removing the glue.
30th Sep 2017, 4:06 am | #13 |
What about the glue used to adhere rear view mirrors to the windshield?
I never had any luck with superglue & glass. I have used Duco Cement with success on china, but I have not used it for any sort of eating glassware. |
2nd Oct 2017, 7:11 pm | #14 |
If the site of the joint will not be in view, the very best stuff is the thick black adhesive used to glue in car windscreens. Wear disposable gloves though, as it's VERY sticky.
Regards. |
2nd Oct 2017, 7:20 pm | #15 |
Given that you've used superglue [which has failed] you now have a problem that unless you deploy some serious cleaning chemistry and/or mechanical treatment your bond becomes:
glass-superglue-[new adhesive]-superglue-glass What can you use to rid the mating faces of contaminating superglue-residue before you try again? |
2nd Oct 2017, 7:57 pm | #16 |
Fire
Lawrence. |
2nd Oct 2017, 8:39 pm | #17 | |
Scraping? or nail varnish remover. Does the job perfectly.
Al |
3rd Oct 2017, 6:40 pm | #18 |
My original need is now not relevant, but the general topic is, since repairing cracked glass (in this case a radio dial) is something that many of us have met in the past and may well do so in the future.
At present, I have nothing to add to this thread - but others may have, of course. Al. |
