24th Dec 2017, 6:35 pm | #1 |
AVO 8 Mk 5
I picked this one up recently for a not a lot and going over it this afternoon found it's reading low on DC volts. Not looked at AC volts. I've cleaned all the switchery and checked the resistances which seem fine. Below are the readings I'm getting, 3V range looks slightly high, others are low except for the 10v on the 10v range oddly.
Input/Range/Result 2.50/3/2.55 2.50/10/2.38 5.00/10/4.8 7.50/10/7.3 10/10/10 10/30/9.9 98/100/96 252/300/265 325/600/314 I'm thinking it's the 3V range resistance(s) that are out and I need to look harder at them but does anyone have any other thoughts? This one came with as a complete kit, case, leads, the lot so I thought it deserved some wider knowledge input and attention before relegating it to the pile of shame. Thanks - Andrew
Invisible airwaves crackle with life. Or they should do. BVWS Member |
24th Dec 2017, 9:02 pm | #2 |
Re: AVO 8 Mk 5
I'll watch this with interest, as I've got a few which read low here and there and am wondering how easy it would be to get them back into cal.
Avometer, vintage Fluke and Marconi collector. Also interested in vintage Yaesu and KW. |
