Old 10th Oct 2017, 9:28 am   #1
Hoddbod
Default Ferguson Studio 100D.
Hi. I have a Ferguson Studio 100 D Unit. What is the tracking weight on this player. It also has a push in /out button for stereo/mono.Is this for the radio only, or will stereo records play mono if in mono position.?
Hoddbod.
Hoddbod is offline
Old 10th Oct 2017, 9:35 am   #2
Edward Huggins
Default Re: Ferguson Studio 100D.
The push in button is usually used for the playing of records in either stereo or mono. However in bad FM radio signal strength areas, using Mono when recieving a noisy stereo broadcast will give a cleaner signal. All AM broadcasts are mono only. The ideal tracking weight on the tone arm should be between 2.5 and 3 grams, but given the rather budget build of this, up to 4 grams will be fine.
Edward.
Edward Huggins is online now
Old 11th Oct 2017, 10:17 am   #3
Hoddbod
Thank you for your reply. Where can i get a user manual for this model?
Hoddbod.
Hoddbod is offline
Old 11th Oct 2017, 10:32 am   #4
Edward Huggins
It may be quite hard to find a User Manual but you may be more likely to source a Service Sheet/Technical Manual which may cover some of the information that you seek. This is a rather entry level/basic stereo unit, so it rather depends on what you expect from it and what you want to use it for.
Edward.
Old 12th Oct 2017, 7:59 pm   #5
Hoddbod
Default Cassette Drive belts
Hi. Can anybody tell me what cassette player was fitted to a Ferguson Studio 100 D. And how do i get drive belts for this machine.
Hoddbod.
Hoddbod is offline
Old 12th Oct 2017, 11:37 pm   #6
simpsons
Default Re: Cassette Drive belts
Should you enter Ferguson Music Centres into the UK Vintage Radio search box, or Google a number of threads will be shown. In addition, entering the same on ebay will show you that the cassette deck is used on a number of models which would help narrow down your search.
To save you time, look for a Ferguson 20D posted by a fellow member who you will need to contact for the supply of belts.
Good luck
Chris
simpsons is offline
Old 13th Oct 2017, 12:50 am   #7
joebog1
I have seen this question numerous times before!!
This information is from Australia, but I believe the method of measuring belt diameter/length is world standard ( PLEASE dont kick me too hard if I am wrong)
One thing that is standard is the number of belts still available, along with pinch roller tyres and complete capstan rollers.
I offer this info from a local catalogue and is for general information only.
Joe
joebog1 is offline
Old 14th Oct 2017, 12:10 am   #8
simpsons
Cricklewood Electronics have a selection of flat and square cassette drive belts in stock. Also, it is worth noting that Ferguson must have bought in the cassette unit and it looks very similar to one used by Dynatron in, for example, the SRX30.
Should working out the belt size a challenge, then troll through ebay music centre adverts looking for a similar cassette unit. Then see what information is available.
Chris
simpsons is offline
Old 14th Oct 2017, 9:54 am   #9
Hoddbod
Default Speakers for Ferguson Studio 100 D
Hi.
The speakers with my unit are pretty basic,and the sound quality is not very good. What speakers can I replace them with? The wire connectors are the bar and pin type. Modern replacements don't seem to use this type of connector.
Any advice will be appreciated.
Hoddbod.
Hoddbod is offline
Old 14th Oct 2017, 11:15 am   #10
Edward Huggins
Default Re: Speakers for Ferguson Studio 100 D
You mean DIN plugs. You can cut these off and then bare the wires and fit (usually) Banana Plugs for newer speakers. Note their + and - polarity.
However, you don't necessarilly need "new"speakers.
You can get excellent 1970s/1980s speakers off the Auction sites for up to £50.00. Go for Tannoy, Celestion, Wharfedale, Goodmans - they will sound super on your 1980s Ferguson. They may even have DIN sockets on them.
Edward.
Old 14th Oct 2017, 11:23 am   #11
Audio1950
The speakers will only reproduce what the amplifier feeds into them, so replacing the existing ones will not improve the quality of the sound to any great degree.
Audio1950 is offline
Old 14th Oct 2017, 11:37 am   #12
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
What you call the 'Bar & Pin' connector is the one-time DIN Standard speaker plug which was used by many manufacturers in the 60s & 70s, maybe later. DIN speaker plugs are still available from Maplin and on eBay, etc. They can easily be fitted to any speaker lead. Solderless versions are/were available. As Audio 1950 says, speakers can only reproduce what is fed into them, although a pair of 2-way types from such as Celestion, Wharfedale, etc., may offer some improvement. Most HiFi Speakers are nominally 8 ohm impedance so will be OK to use with your Music centre.
'LIVEWIRE?' is offline
Old 14th Oct 2017, 11:41 am   #13
paulsherwin
paulsherwin's Avatar
Better speakers will improve the sound, though they won't magically transform a very basic system into something wonderful.
As Edward says, a pair of mass market 70s hifi speakers would be ideal, as they tend to have a very forgiving sound.
paulsherwin is offline
Old 15th Oct 2017, 6:37 pm   #14
kirstyd
Back in the late 70's I had a Panasonic music centre 3000 [I think] all silver with perspex lid and about 20 watts per channel. I'ts speakers however were just the usual chip board covered in little more than Fablon, housing a 6 inch driver and a small tweeter. My mate's parents' had a Bang and Olufsen music centre [a few years older than mine] One day [while they were out] we tried the B&O speakers on my Panasonic. The difference in sound was astounding to say the least.
kirstyd is offline
Old 15th Oct 2017, 7:08 pm   #15
Nickthedentist
Nickthedentist's Avatar
I've seen the foam surrounds on the speakers that go with the Ferguson Studio series machines deteriorate to dust, leading to really bad sound quality.
It's possible that pretty much any working pair of speakers might make it sound massively better.
Nickthedentist is offline
Old 19th Oct 2017, 2:13 pm   #16
Hoddbod
Default No Power
Hi. I have a Ferguson Studio 100D unit. I have been trying to repair the cassette player. One of the capstan Tyres was stuck and i cleared that. I fitted a new drive belt and installed the unit. It played but with very erratic speed. I removed the unit again and the the screws that held the large drive wheel were loose so i tightened them and replaced the unit. But it would not play at all. There was no power. I put all the cable connectors as before but no go. i can't see what the problem is. What is the problem?. The record deck works OK. Can any body give any ideas.
Hoddbod.
Hoddbod is offline
Old 19th Oct 2017, 2:33 pm   #17
Several threads concerning the same piece of kit merged.
There may be inconsistencies.
Station X is online now
Old 19th Oct 2017, 6:50 pm   #18
'LIVEWIRE?'
Hodbod, if you mean the screws which hold the Flwheel in place, one in particular usually has a small coil spring underneath, This must not be screwed up tight It is adjusted to give a small amount of vertical play(usually 2mm at most) between the bearing and the flywheel. This doesn't explain why the cassete mechanism wouldn't run at all, though.
Old 3rd Dec 2017, 11:57 am   #19
Hoddbod
Hi. What deck is in my Ferguson Studio 100 D, Garrard or BSR. I think it is a BSR, but there is no name on the the deck, just Ferguson. Here is a photo.
Hoddbod is offline
Old 3rd Dec 2017, 12:20 pm   #20
'LIVEWIRE?'
Default Re: Types of record players
AFAIK that is a BSR (not sure which model)
