Old 20th Jul 2019, 7:10 am   #1
6AL5W-Martin
Default µTek Restoration: the 213
it is always the same with this cuties: The recharchable NiCd Batteries are rotten and you buy the scope "not working", what else ...
Tek made 5 of them, here are the differents and batteries.
211 = 1Ch .5MHz it use 2x 5-Pack of AA Type NiCd
212 = 2Ch .5MHz it use 2x 5-Pack of AA Type NiCd
213 = 1Ch 1MHz it use 2 pcs. of D Type NiCd
214 = 2Ch .5MHz storage, it use 2x 5-Pack of AA Type NiCd
221 = 1Ch 5MHz it use 2x 5-Pack of AA Type NiCd
All of them except the 213 have a common problem: The both battery packs are standing on the lowercase board. When they make leakage the acid soup will flow in the electronics and destroy there something. The restoration of that is good to bump the head on the table !
Tek 213 have 2 of the fat D Cells, and large holes in the board for them.
So, when this become leakage, the acid soup will flow in the case cover and you can hope the boards are allready.
This is the second 213 in my collection, buyed "not working", from the bay.
It was expensive, they are mostly expensiv.
Battery: RIP
Plug from Batterie: destroyed
a missing knob POS
missing the hook (no problem)
missing the AC Adaptor for NEMA to the national AC Plug (no problem)
missing the pouch (no problem, we make a rebuild here very closed to the original)
Repairs: the plug, + new NiCd D Cells
a lot of washing.
Tests: DMM all ranges, Beam all ranges, Charging Voltage Tek ON and Tek OFF = 2,58V at the batteries = OK.
and here are some pictures. The family picture is missing the 211, you see there from left to right: 212, 213, 214, 221 and the little DSO 222
greetings
Martin
ID:	186965   Click image for larger version
ID:	186966   Click image for larger version
ID:	186967   Click image for larger version
ID:	186968   Click image for larger version
www.wellenkino.de Vintage Scope restorations
6AL5W-Martin is offline
Old 20th Jul 2019, 7:11 am   #2
6AL5W-Martin
Default Re: µTek Restoration: the 213
213.
ID:	186970   Click image for larger version
ID:	186971   Click image for larger version
ID:	186972   Click image for larger version
ID:	186973   Click image for larger version
Old 20th Jul 2019, 7:12 am   #3
6AL5W-Martin
The µTek family picture (missing 211)
212, 213, 214, 221 and the DSO 222.
213 is the only of them what have a on screen DMM.
greetings
Martin
