31st Aug 2019, 1:07 pm | #1 |
Sony HMK 70 help needed
Hi, I wonder if anyone could give me some advice of how to reset the mechanism of my Sony HMK 70. I purchased it from a charity who advertised it on line and insisted on posting it. When it arrived the Plato had come off its location point, I replaced it but it makes contact with the base of the turntable. The centre spindle lifts up and down and when I look at the mechanism I can sort of work out how it works, the Plato will turn then the spindle drops down making the Plato catch the base.
Am I missing something silly ? Any help would be much appreciated Regards, Matthew. |
31st Aug 2019, 1:47 pm | #2 |
Re: Sony HMK 70 help needed
31st Aug 2019, 1:53 pm | #3 |
Hi Matthew, welcome to the forum.
A common problem is failure of the lower bearing thrust washer which supports the turntable shaft and results in the turntable almost touching the deck. Attached link to an older thread showing bearing location. https://www.vintage-radio.net/forum/...59&postcount=3 Well worth fixing but can you confirm if the thrust washer has failed? Rich
To an optimist a glass is half full; a pessimist half empty; an engineer twice as big as need be! |
31st Aug 2019, 2:55 pm | #4 |
Hi Rich, thanks for your reply and guidance. What I can't work out is why the centre spindle teeth are below the point that's required for them to make contact with the teeth on the large white disk with teeth, excuse my lamen terms, I don't know the correct names for the parts. How does the splindle lift in order to make contact ?
Regards Matthew |
