26th Jan 2019, 1:08 pm | #1 |
Latest find- Philips PH4212 (Cossor CR4212)
Picked this up locally going cheap, seems to be in excellent condition.
Case isnt damaged anywhere and the inside looks very very clean! FM band goes to 104 and two good speakers but I doubt it's actually stereo. EL84 looks gone to air though, another one , I shudda order two last time ! Mains trafo looks beefy, this could have powerful audio! Havn't powered up yet, plan to do regular checks first. But seller claims it was working except on FM. I didnt like it at first, its a bit of an ugly duck. But its growing on me now I have it on the shelf. What ya think folks? Will she fly and sound good? Cheers Ray Last edited by Cathode Ray; 26th Jan 2019 at 1:14 pm. |
26th Jan 2019, 1:22 pm | #2 |
Re: latest find- Philips PH4212 (Crossor CR4212)
Nice radio!
Looks like this one is similar to it, though no guaranties: https://elektrotanya.com/siera_arist.../download.html But at least the magic eye is different, it is an EM84. Regards, Peter |
26th Jan 2019, 1:29 pm | #3 |
Thanks Peter, nice one.
Acually that service doc looks exact, everything matches. Happy days, great to have a service doc with alignment procedure. Cheers for that Ray |
26th Jan 2019, 2:37 pm | #4 |
This looks like the quite rare Bi-Amped model. Those 5.25" speakers have a very good compliance and have tweeter cones.
Edward. |
26th Jan 2019, 3:27 pm | #5 |
Re: Latest find- Philips PH4212 (Crossor CR4212)
Internals look very clean and tidy
Alan G6PUB, BVWS |
26th Jan 2019, 4:45 pm | #6 | |
Ray |
27th Jan 2019, 2:45 pm | #7 |
Re: Latest find- Philips PH4212 (Cossor CR4212)
Opened it up today.
The original owner never removed the transit bolts, they were still in place with red labels instructing removal ! It not a straightforward chassis removal: Both speakers needs to be unsoldered. LHS speaker (when viewed from rear) needs to be removed Tone Switch board needs to be unscrewed from case Front aluminum grill needs to be unscrewed from case. Ground wires to bottom shield need to be unscrewed. Inside chassis looks clean, but fairly dense component assembly. Tuning cables are all in place (thankfully) but a bit stiff, some light oil/grease should help. The main SW MW dial indicator has broken but is repairable. it uses inductor tuning on VFH, two plunge rods with very delicate wires, all in working order! Some resistors look a bit baked, may need to change a few. And I can only see a couple of Black Tar caps which no doubt will need changing. In general would the yellow dip caps be ok ? Cheers Ray Last edited by Cathode Ray; 27th Jan 2019 at 2:50 pm. |
27th Jan 2019, 3:16 pm | #8 |
Hi Ray,
Those "yellow dipped" caps are also known as Mullard mustards and are 100% reliable, so no worries there. John Joe. |
27th Jan 2019, 3:43 pm | #9 |
The chassis looks VERY similar to a Stella radio I have even down to the tone control buttons. That also has all the original mustard caps which are perfect. You will need to change the two black tar 'roadblock' caps around the output transformer as they will be very leaky by now. Other than that it should be good to go (unless it does need a new output valve of course).
It should sound very good....
27th Jan 2019, 4:14 pm | #10 |
Thanks lads, seems like it won't need much work then.
I've not started measuring components yet, just spent some time sorting out the tuning dial mechanism with a touch of oil. Running nice and smooth now. More to come. And I'll check out the Stella connection, could be a relative ! Cheers Ray |
27th Jan 2019, 4:38 pm | #11 |
The Stella connection is a simple one. By this date the Cossor and Stella radio and tv brands were owned by Philips.
Inside they are Philips sets with some cabinet tweeks to appeal to different demographics. Simples Cheers Mike T
27th Jan 2019, 4:45 pm | #12 |
Cheers Mike, that was simple alright.
By any chance do you have a component list on Crossor model? I've got a schematic and location drawing, but no comment list. Im having to read values from the diagram which is a bit scratchy in parts. Thanks Ray |
27th Jan 2019, 7:15 pm | #13 |
I'm not sure I don't tend to have much interest in Philips made Cossor sets. Although I have 2 examples of this model neither restored as they both work well.
All my circuit info is in Poole and I won't be back there for a few days. If you need it in a hurry Paul has the manufacturers manual here https://www.service-data.com/section.php/1468/1/m11002 Cheers Mike T
27th Jan 2019, 9:19 pm | #14 |
Looks a nice, and unusual, radio - Definitely replace the two big black "Tar bomb" capacitors adjacent to the transformer - those are known to have 'issues' and can take-out an output-transformer if they go short-circuit.
Also I see one capacitor that has a translucent yellow encapsulation with red text - it looks non-original and I _suspect_ it may be one of the RIFA/WIMA resin-encapsulated type that are also known to have 'issues' because with age the resin cracks and allows air/moisture in. Do not trust these! |
27th Jan 2019, 9:33 pm | #15 |
Hi Ray,
I have the Cossor version, very reliable radio and mine is in regular use. I didn't need to do much to it and I used the manufactures Service Notes available here: https://www.service-data.com/section.php/1468/1/cr4212a There's no separate component list but they're all shown with values on the diagrams. Good luck with it. John |
27th Jan 2019, 9:34 pm | #16 | |
be great if you could check when you have time. I downloaded the service sheet from service-data.com but still no component list is provided. Perhaps it was never issued, anyway be good to know for sure. Thanks Ray |
27th Jan 2019, 9:35 pm | #17 | |
I'll be sure to swap it out, thanks for the tip. Ray |
27th Jan 2019, 9:38 pm | #18 | |
Yours looks identical and in great condition! Yes it seems to need very little by way of restoration, hopefully it will be shack radio as it fits nicely on my top shelf. I suspect component lists were not issued for this model, and like you say it's got the values on the schematic, my version is just a bit fussy but I can make out 90% of them. Cheers Ray Last edited by Cathode Ray; 27th Jan 2019 at 9:49 pm. |
27th Jan 2019, 10:59 pm | #19 |
Very interesting set. Philips did this on the continent sometimes as well: release a sub-brand set under their own name when there was seen a commercial need for it. Though, I''v never seen them use the letters PH for it. Usually just SA (Aristona/Siera). Is PH4212 the full model number? What letters are in front of the serial number? PL? If PL, that would indicate made in Leuven, Belgium, as most of the plano design sets were.
27th Jan 2019, 11:19 pm | #20 |
Hi Maatren,
The serial has faded but the prefix is PL as you mentioned. Ray |
