Old 9th Nov 2005, 9:05 am   #1
taipai_royal
Default TRF reaction control types.
Please can anybody tell me why a variable condenser is employed to control reaction rather than a variable resistance, in these early sets.
taipai_royal is offline
Old 9th Nov 2005, 8:37 pm   #2
quantum
quantum's Avatar
Default Re: TRF reaction control
Well, depending on the circuit you may find either method, but remember that in early TRFs the reaction control would get more use than a volume or tone control, and a variable cap would stand up to constant use a lot better than a variable resistor. Many leaky-grid detector circuits using reaction would also find the application of reaction smoother with a variable cap than using a variable resistor to control anode or screen voltage.
quantum is offline
Old 9th Nov 2005, 9:57 pm   #3
jim_beacon
jim_beacon's Avatar
The variable resistance control is normally applied to pentodes, where you use the varible resistor to vary the screen potential, and hence the gain.
Early sets used triodes, and here it is easier to apply a variable level of feedback, rather than vary the gain of the active device, hence a series tuned circuit is used to apply the feedback.
The TRF discussed in the current thread uses variable resistance to vary the anode potential of the triode detector, but I suspect that the control may be a little critical, depending on the coupling of the feedback and tuned circuits, it will also be very dependant on the slope of the valves characteristics.
Jim.
jim_beacon is offline
Old 11th Nov 2005, 10:50 am   #4
taipai_royal
Thanks guys, The circuit I was hoping to modify supplies current from the anode of the triode detector then through the MW LW reaction coils via a variable condensers to earth. If I replaced the (faulty) condenser with a variable resistance pot, would it work?
Regards Graham.
Old 11th Nov 2005, 12:34 pm   #5
quantum
quantum's Avatar
No, not without modification. If you replace the variable cap with a variable resistor then the HT voltage can be shorted to earth through the resistor, and on its minimum setting you risk burning out the reaction coils. You would need a blocking cap in the lead connecting the anode to the reaction coil. Even so, even with the resistor at maximum some feedback would still be getting to the reaction coils and you might have trouble with maintaining stability. The cap normally controls the amount of reaction down to zero.
I think you might get a better response in the reaction if you connect the end of the reaction coil which normally connects to the variable cap (the other end of the variable cap going to the earth/chassis) directly to earth itself, and connect your variable resistor (about 50k or so) across the reaction coil, while disconnecting the connection which goes to the anode. The wiper of the variable resistor connects to a small cap (500pf) which is connected to the anode of the detector. Thus the resistor controls the amount of feedback going into the coil from zero.
quantum is offline
Old 12th Nov 2005, 10:04 pm   #6
taipai_royal
Thanks Quantum, I will take your advice and try the seconed option.
Regards Graham.
