18th Apr 2021, 8:29 pm | #1 |
FM radio distortion problem.
My trusty old National-Panasonic alarm clock radio is sounding progressively worse. Of course it has never been a Hi-Fi radio but now there is noticeable distortion.
It sounds like when you turn up the volume too high on a transistor radio or when you hear an FM station slightly out of tune. Since it has been detoxicating for a while, can it be because of dried-out capacitors? Do transistors go bad in this manner? |
18th Apr 2021, 9:29 pm | #2 |
Re: FM radio distortion problem.
One thing off the beaten track is a dried-up electrolytic that gets forgotten about, the floating one at the end of a ratio detector.
19th Apr 2021, 2:38 am | #3 |
Make sure the speaker is OK first. It could be rusty or the voice coil may be rubbing.
Can you connect a good speaker to the amplifier output? Is it distorted on the Medium Waveband? Last edited by Silicon; 19th Apr 2021 at 2:39 am. Reason: Another question added. |
24th Apr 2021, 7:52 pm | #4 |
Thank you for your thoughts.
It turned out to be easy to fix, i opened it up and made some measurements and I immediately found a clue in that the DC rail voltage dropped by about 30 percent when the radio was switched on. I replaced the electrolytic smoothing capacitor and all was well again Regarding medium wave we don't have any such transmitters in Sweden anymore and I could only find one, noisy station on that band. |
