Old 29th Oct 2009, 5:45 pm   #1
Pete_kaye
Pete_kaye's Avatar
Default What is this?Light dialling display?
Found in a box with other old 60's and 70's phone spares.Looks like it would flash on /off when a call is received.No numbers or codes
Pete_kaye is offline
Old 29th Oct 2009, 6:03 pm   #2
YT2095UK
Default Re: What is this?Light dialling display?
is there a plug or something on the other end, or bare wires (and how many)?
YT2095UK is offline
Old 29th Oct 2009, 6:14 pm   #3
Pete_kaye
Pete_kaye's Avatar
About 8 leads coming out,of single core wire.
Old 29th Oct 2009, 6:19 pm   #4
YT2095UK
does the light depress Into the box at all? it looks a bit like a panic button to me with those contacts, some wires other than Zone could be Power and Tamper?
purely a guess though.
YT2095UK is offline
Old 2nd Nov 2009, 3:47 pm   #5
Pete_kaye
Pete_kaye's Avatar
Yes the orange button does depress.I'm not sure what 'Zone ,Power and tamper' mean.
Old 2nd Nov 2009, 3:59 pm   #6
ppppenguin
ppppenguin's Avatar
Definitely part of an alarm system if that's what the wires are actually for.
Power: Usually 12VDC, exactly what it says
Zone: Connected to the alarm control unit. If the zone ciruit is broken, an alarm is sounded. Alarms are usually divided into zones so that the controller can indicate which door, widow etc has been violated.
Tamper: A continuous loop to each sensor etc to verify that the cable or sensor hasn't been tampered with. Typically cutting the cable or removing the cover from a junction box or sensor will break the tamper loop.
ppppenguin is offline
Old 2nd Nov 2009, 4:29 pm   #7
Pete_kaye
Pete_kaye's Avatar
From what era are you describing?this item was in with old bakelite phones and other 50's stuff.
Old 2nd Nov 2009, 4:35 pm   #8
YT2095UK
I would say 60`s in my opinion.
YT2095UK is offline
Old 2nd Nov 2009, 4:53 pm   #9
Framer Dave
Originally Posted by ppppenguin View Post
...widow etc has been violated.
More complex than it looks then!
Framer Dave is offline
Old 2nd Nov 2009, 6:32 pm   #10
Station X
Station X's Avatar
A french widow I assume.
Graham. Forum Moderator
Station X is online now
Old 2nd Nov 2009, 6:56 pm   #11
Framer Dave
"affording delightful prospects" I expect.
Dave
Old 2nd Nov 2009, 7:07 pm   #12
ppppenguin
ppppenguin's Avatar
I feel no shame being placed in the company of the late great Gerrard Hoffnung.
Old 2nd Nov 2009, 7:09 pm   #13
Station X
Station X's Avatar
French widows in every bedroom then?
Old 2nd Nov 2009, 7:36 pm   #14
Framer Dave
Mais oui, naturellement.
Mes amitiƩs,
Dave
Old 2nd Nov 2009, 8:39 pm   #15
YT2095UK
trez been mon amy, trez been! </dell boy>
YT2095UK is offline
Old 16th Oct 2011, 10:46 pm   #16
JohnBHanson
Its a switch - push to turn on, and twist to turn off. However you can also push it hard to make another set of contacts, and there is a solonoid to release the latch.
Hence press it hard to buzz an extension, it will be held in while the call is in progress - twist it to release the call or release remotely by using the solonoid - used as part of an entry phone system.
JohnBHanson is offline
Old 16th Oct 2011, 11:44 pm   #17
Darren-UK
Originally Posted by JohnBHanson View Post
solonoid
It works on its own then?
Darren-UK is offline
Old 17th Oct 2011, 6:25 am   #18
JohnBHanson
Well I remember a version of this with three buttons in a remote unit that was used as an entry phone - the buttons were coloured green/amber/red for enter/wait/engaged. I used it to control model trains using the solonoid release connected together via emergency stop buttons. It worked well.
Old 17th Oct 2011, 3:27 pm   #19
BGmidsUK
Presumably you mean giving a gentle push latches it but is user-releasable by twisting, whereas a firm push latches it via the solenoid?
Brian
BGmidsUK is offline
Old 17th Oct 2011, 5:54 pm   #20
Station X
Station X's Avatar
solonoid
Is this connected with Solon soldering irons?
