Old 15th Jun 2022, 9:20 pm   #1
thejazzageuk
Default PYE AC4D restore help
I saw this rather nice Pye radio in an antique shop in Llangollen recently and decided to give it a new home.
As you see from the pics, its a bit tired and a few bits are missing. I'm trying to decide whether to just restore the cabinet to look nice, or whether to try to get it working again.
I'm leaning towards the former, in which case I guess I need to:
1) remove the chassis from the cabinet
2) sand the cabinet
3) re-varnish the cabinet (Spray lacquor?)
4) find suitable speaker cloth and fit
5) Try to locate missing knobs.
Has anyone here restored this or similar cabinet before? Any advice/ comments gratefull recieved. I would love to know who owned this throughout its life...
ID:	259101   Click image for larger version
ID:	259102   Click image for larger version
ID:	259103   Click image for larger version
thejazzageuk is offline
Old 16th Jun 2022, 8:34 pm   #2
Ed_Dinning
Default Re: PYE AC4D restore help
Hi, I've done Pye G, & S sets, of a similar style and age before, well worth the effort.
Main thing to watch out for is the ganged cap, typically made of monkey metal and quite fragile.
Built a bit like a meccano set complete with chain drive
Ed
Ed_Dinning is online now
Old 22nd Jun 2022, 5:27 pm   #3
thejazzageuk
Thank you Ed_Dinning
Did you do a cosmetic refurb and get them working?
Not quite sure what you mean by the ganged cap- is it visible on my photo?
I've now removed the chassis and started to sand the case. I plan to do this very lightly then spray with clear laquour. If anyone has advice for this process please let me know.
I've also ordered some new grill fabric from the US- see photo.
Still not sure whether to attempt to get it functioning- the chassis does not seem too bad so it may be possible. There are 3 valves missing, an MH4 and 2 off S4VB valves. I've oredered an MH4, but the S4VB valves seem very expensive- is there an alternative?
ID:	259581   Click image for larger version
Name:	original fabric.jpg
ID:	259582   Click image for larger version
ID:	259583   Click image for larger version
Old 22nd Jun 2022, 9:17 pm   #4
Ed_Dinning
Hi , yes a friend did the cabinets and I did the elec tronics, for one of then I had to make a ply back.
I think mine were a fairly light colour, so your scheme should work OK
From memory the ganged cap or tuning cap was inside a box and had a chain drive from the tuning knob. Not directly visible on your photo.
There should be some near equivalents to the S4VB. Try searching the forum with that number
Ed
Old 6th Aug 2022, 3:18 pm   #5
thejazzageuk
Thanks.
I have now sanded and restored the cabinet, and fitted the new speaker grill cloth. Here is how it looks so far.
Next step I'm thinking of getting it back to working order, likely to be a long project though. I will try to keep posting photos as I go along.
ID:	262306   Click image for larger version
Old 6th Aug 2022, 9:06 pm   #6
Silicon
The back view of that set looks interesting.
Have you considered making the back from toughened glass or clear acrylic?
Some ventilation holes would be needed.
Silicon is offline
Old 6th Aug 2022, 11:00 pm   #7
Gridiron
I repaired the set I have some time ago (AC4D also called the Twintriple ), can't remember all the details now, but it was not designed with servicing in mind as with other sets of this period (1930), everything in different compartments with covers held on with lots of screws. I remember some of the high value wirewound resistors being o/c. The tuning condensers are not chain driven in this set, being mounted horizontally at the front top of the set, not visible in the photos (in front of the screening).
Mike.
Gridiron is offline
