Old 17th Mar 2018, 10:23 am   #1
normanmk1
Default WS19 variometer seating plate
I am needing to make up a seating plate for my variometer, could someone kindly supply me with the dimensions? I estimate that it is about 6" long by 4" wide - does that sound about right? Also is this a flat plate or are the long edges turned up a bit to add support to the packing block
I am then going to have to make up the packing block - any idea what material I should use? Plastic?
Any help or advice would be much appreciated.Thank you.
All the best,
Kevin.
normanmk1 is offline
Old 18th Mar 2018, 8:47 am   #2
G3VKM_Roger
G3VKM_Roger's Avatar
Default Re: WS19 variometer seating plate
Kevin,
May not help you much but attached is a photo of a plate I sold on ebay several years ago. A wise move to make your own, mine sold for more than the WS19 that I auctioned at the same time!
Roger
Name:	19 Set_variometer_plate.jpg
G3VKM_Roger is offline
Old 18th Mar 2018, 12:42 pm   #3
G4XWDJim
G4XWDJim's Avatar
I have a drawing I made of the curved Ebonite/Bakelite block with measurements noted but I moved house recently and it's still in storage. In a month's time I can help if you're not in too much of a hurry.
It measures about 5" x 3" from memory.
Jim
G4XWDJim is offline
Old 18th Mar 2018, 6:29 pm   #4
normanmk1
Hi Guys,
Thanks for your replies.
Roger - It has surprised me just how expensive the ancillary bits and pieces are, so if I can make them I will!
Jim - If you could let me have the measurements, when you are sorted, that would be much appreciated. Thank you.
All the best, Kevin.
