Old 9th Mar 2018, 8:19 pm   #1
sunthaiboy
Default STD Jack....but smaller
Hi Guys,
I have acquired a 1959-61 vintage R&S receiver. It appears to have a headphone jack socket. I thought it was a standard dual-pole 6.35mm/1/4" jack type, but it's smaller dia. approx. 5.05mm and slightly shorter. Typical of the Germans to have something special-to-type.
Has anyone come across a jack connector of this type. If yes please get in contact with me. I have turned one up on a lathe, but need a second.
Thanks
sunthaiboy is offline
Old 9th Mar 2018, 8:25 pm   #2
cmjones01
Default Re: STD Jack....but smaller
Sounds like it could be a 'bantam' size (3/16" I think) jack.
Chris
What's going on in the workshop? http://martin-jones.com/
cmjones01 is offline
Old 9th Mar 2018, 8:39 pm   #3
sunthaiboy
Alas Chris, I don't think its a Bantam. They are 4.4mm dia. I may try one....or possibly slide a 4.5mm drill in the hole see if it make suitable contact.
Old 9th Mar 2018, 8:40 pm   #4
Dave Moll
Dave Moll's Avatar
I don't suppose this uses a telephone jack - as shown below - does it?
The diameter of this does measure just over 5mm.
Dave Moll is online now
Old 9th Mar 2018, 8:50 pm   #5
G6Tanuki
G6Tanuki's Avatar
I suspect it's a "316" socket; these were used extensively on telephone and communications-equipment from the 1940s onwards. I've got a bunch of WWII-era ones here, all marked with the "Air Ministry" A[crown]M logo.
G6Tanuki is offline
Old 9th Mar 2018, 9:01 pm   #6
Ted Kendall
No, bantam came a lot later, This was a connector used by Grundig on the 500/700 tape recorders and also by Philips, fell out of use by 1960 and was unavailable by 1965-ish - an article in Tape Recorder refers. Lots of luck or back to the lathe, I fear...
Ted Kendall is offline
Old 9th Mar 2018, 10:23 pm   #7
sunthaiboy
I think it might be a PJ-068 jack (certainly dia wise), but the PJ-068 is a 3-pole mike jack (which might do the job). The one I need is 2-pole speaker/keying jack looking at the socket. I include a photo of a NP3TB-R and my build effort.
Thanks for your replies
