12th Jan 2020, 6:58 pm | #1 |
Teac A300
For something different I took pity on this TEAC A300 cassette deck that’s been sat on a shelf for years. I found belts in the right dimensions and after some aggravation having removed the motor plate assembly and the old belt residue which had turned to goo got them fitted no problem. I thought that was almost job done However nothing’s happening when any of the piano keys are pressed. The deck is powered, fuses ok, I connected my 12v dc power supply to the motor thinking it might be toast but it span up fine the belts were moving the spigot things that the cassette sits on. I have the service manual but don’t find it all that useful. There is a control daughter board on the back of the mechanism which I’ve unscrewed to get access the components being on the bottom. There are voltages on the board but without knowing what I’m looking for I’m a bit stumped as to how to proceed. Does anyone with experience with cassette decks have any suggestions about what to focus on?
Mike |
12th Jan 2020, 8:16 pm | #2 |
Re: Teac A300
Hi Mike,
I am not experienced on cassette desks or Teac (well I do have a Teac X-3 R2R) so cannot offer anything useful. As you say the Service manual is not helpful at all in relation to motor control. Presumably somewhere there should be a proper/full schematic that also shows the control/motor circuitry. Hopefully someone on the forum knows this model or a similar model and can offer some useful information. David |
12th Jan 2020, 8:44 pm | #3 |
Re: Teac A300
This may or may not be helpful. If you search for "Teac X-3 play switch motor failure fix" on "tapeheads.net", there is someone talking about a common failure of the pause and/or the play switch on model X-3 (assume my R2R) , X-300 (I assume your cassette deck) & 22-2 decks.
They detail a relay modification, I think when replacement switch is not available. I am not suggesting you need to do the modification but the accompanying mod drawing (on tapeheads) that shows some pins outs of the control board may possibly be of a little help, particularly if a schematic could be located for the A-300 |
12th Jan 2020, 8:52 pm | #4 |
Re: Teac A300
Just spotted that the full schematic is in the Parts List on hifiengine, that should help a lot.
12th Jan 2020, 8:53 pm | #5 |
Re: Teac A300
As there are 3 switches on the top of the mech, I assume that one of them is a tape in sensing switch - so you need a tape in there, or operate the switch by hand, to switch on the motor. Don't know this machine but it is a fairly common thing on most of the better machines.
12th Jan 2020, 10:11 pm | #6 |
Re: Teac A300
Hi Guys
Thanks ....I did try it with a tape loaded but no joy. I’ll have a read around the suggested links. As an aside Not sure this deck is high end the front that looks metal is plastic. The meters look nice though. I can’t say I’m enjoying working on cassette decks....they seem to be designed to be difficult to service! Oh well I’m learning as I go. Thx |
12th Jan 2020, 10:45 pm | #7 | ||
Re: Teac A300
Sorry I can't help more, my Teac decks are a V580, W525R and W990RX, the only work I've needed done was a new capstan motor in the W770RX - which I wussed out on and had replaced by a service company The 580 and 525 I bought new, while the 990 was a deck I drooled over as a teenager, then found on Trademe for $20 in the mid 00s. |
12th Jan 2020, 10:57 pm | #8 | |
Re: Teac A300
12th Jan 2020, 11:21 pm | #9 |
Re: Teac A300
Yep no worries re persevering ....I’m more likely to fish something out of the skip than chuck it in. Worst case is banishment to the loft! I’ll try & get my head round the schematic but sadly I’m not that up on some of the theory so it’s a slow process. I’ll start with the motor control board.
Mike |
