24th Sep 2022, 5:37 pm | #1 |
Decipher Revox B285 schematic mystery
I have acquired the module for the RF section and If stages of Revox B285 FM stereo tuner. This is a high-end tuner, one is currently up for sale on ebay for $1000. One of its unique features is the initial IF stages: a 3-pole Butterworth bandpass followed by a long-tailed differential amplifier and a 7-pole Butterworth phase linear filter. The filters have asymmetrical designs with different input and output impedance.The scheme can be downloaded from:
https://www.dadaelectronics.eu/uploa...ice-Manual.pdf On page 92 of the scheme, I am mystified by the negative polarity of the power rail at point 8 on the left; -16.5V. At first, I thought there is a mistake in the scheme. But this is also shown as -16.5V for pin 8 of the PCB on page 93. I have attached markings with blue colour traces of the -16.6V power rails. The positive + 16.5V rails are marked red. It looks like the drains for the first pair of BF961 RF amp Q1, Q2, oscillator and collectors of some NPN BJT (Q7,Q8,Q9,Q10,Q11,Q12) are all negative. On the contrary, the differential amp CA3053 (37k resistor at the top, 2.2k resistor at the tail), Q15, Q14 seem to have the correct polarity. I cannot make sense of it. Any idea what is happening here? The polarity seems wrong as indicated in the blue traces. The RF front end also has very peculiar double dual gate FETs. I don't know the benefits of this. Certainly I have never seen this being used in high-end Japanese tuners |
24th Sep 2022, 6:26 pm | #2 |
Re: Decipher Revox B285 schematic mystery
The circuit is just WRONG.
I think the draftsman has slid some segments of power rail to the wrong place. If you look at the PCB drawing you can clearly see that IC1 connectes to pin 7 (+ve 16.5v supply) via R53 and L23. I did not bother looking any further but the circuit needs modifying to match the PCB. Good luck unscrambling that...
George |
24th Sep 2022, 6:45 pm | #3 |
Dual gate MOSFETs have been steadily vanishing from catalogues over the past few decades. They were always seen as low power consumption champions. Running a pair in parallel doubles the Gm and the Id, so helping large signal handling by 3dB and avoiding unobtainable devices. It also keeps the Z down and makes for easier matching into high-Q RF filtering sections. Running low L and high C (lots of varactors) keeps the signal voltages down on the varactors and so reduces intermod effects.
The whole machine is a derivative of the B261 tuner, modernised a little in some areas, simoplified and cut down in others. They've had to make space for an AM section, and for an optional amplifier. The B261 was purely an FM tuner and went with either the B251 or B252 to handle amplification. It retains the LC filtering which can be done somewhat better than off the shelf ceramic types. The linear phase characteristic lies in the choice of pole locations, otherwise it's a simple enough coupled resonator structure. They've gone to a straight-forward PLL FM discriminator, rather than the B261's pulse-count type with its length of coax cable delay line. -16.5v has an error on the schematic. It goes to some things which need it, but the line continues on to several things which need the positive rail. Someone went cross-eyed and extended the wrong line! David
24th Sep 2022, 6:50 pm | #4 |
Thanks. This confirms my doubt. I will use Photoshop to trace out the rest of the negative rail. I was going to power it up with +16.6V and -16.5V without powering the +36V oscillator and synthesizer sections. I would apply appropriate voltage to the varactor sections and inject oscillator input from signal generator to see if I can power up the RF sections. I dont want the magic smoke coming out if the schematic has errors.
24th Sep 2022, 7:01 pm | #5 | |
I have been probing the values of L with De-5000 of the varactor sections and noticed unusually large L over 250nH. I guess the readings can be wrong with the inductor in parallel with the varactors and trimmers. |
24th Sep 2022, 8:18 pm | #6 | |
You have to be able to flip between admittance and impedance, resistance and conductance as well as positive and negative values once you get this comfortably mastered, then diagrams get more animated. There are many symmetries and equivalences which can save a lot of work. If a capacitor does something, you can make a safe bet that an inductor does the exact opposite in all respects. And vice-versa. Memorise one, and get the other for free! David.
24th Sep 2022, 8:23 pm | #7 |
I have marked the negative rails with blue and cyan; positive rails with red and orange.
During the manufacturing phase, the engineers would use the scruffy but correct schematic for the manufacturing of PCB. Then they passed the original schematic to a draft man who copied it wrong. |
24th Sep 2022, 8:31 pm | #8 | ||
I keep bumping into admittance, susceptance and conductance when I read about the use of Smith charts for impedance matching. They are kind of ying yang in chinese, sometimes giving me headache, my brain like an aircraft in a flat spin. I have to overcome my phobia with admittance, susceptance and conductance before i can transcend to the next level. |
24th Sep 2022, 9:29 pm | #9 |
Going from your marked-up pcb I reckon there is just one spurious join in the circuit.
George |
24th Sep 2022, 10:57 pm | #10 |
