Old 21st Jul 2022, 11:24 am   #1
Pcspike
Default Leak Stereo 30 Plus
Recently acquired a Leak Stereo 30 plus with only one channel working, the problem is that it blows the 1.5 dc fuse each time it’s powered up. Both preamp boards are ok when used with the good power amp board.
I’ve checked the faulty power amp board, changed the electrolytic caps and checked all the resistors and transistors. However, there is a one single component that I’m having difficulty identifying, and suspect that this could be the problem. This components is linked between one of the terminals of P5 to the resistor R54. It looks like a resistor with the colours red, black, brown, and white on the body which doesn’t seem to relate to anything as far as I can see. I noticed that it looks very much like C31, a capacitor shown on the circuit diagram. Can anyone tell me what this is?
I found (on one attempt) that with the resistance turned up on p5 the fuse held but when I turned it down slightly it blew. Resistor R54 is ok, which makes me suspect the component linked between R54 and P5.
I noticed too on the schematics that there are two diodes next to where P5 is located but I cannot locate them on the amplifier or board.
I would appreciate it if any of you can help me with this.
Have included some photos which should help illustrate what I am (trying to) explain.
Thanks
Pcspike is offline
Old 21st Jul 2022, 12:45 pm   #2
snowman_al
snowman_al's Avatar
Default Re: Leak Stereo 30 Plus
Hi and welcome.
The component between P5 and R54 is a capacitor, just like C31.
It is 200pF and is marked as C37 on most diagrams. Unlikely to be a problem.
The diodes are not mounted on the board, they are on the output transistor heatsink, from memory. The connections are marked as capital letters and they are between C and J on the diagram. Follow the wiring.
Name:	Screenshot 2022-07-21 125014.jpg
snowman_al is offline
Old 21st Jul 2022, 12:52 pm   #3
Trevor
The schematic and pc board do not match
The schematic is for the germanium stereo 30 the pc is from a silicon 30 plus
Its always dangerous to swap the driver boards over as this can create more damage
I would first check the output transistors for shorts before going any further
Trevor is offline
Old 21st Jul 2022, 1:00 pm   #4
snowman_al
snowman_al's Avatar
Hi Trevor,
The diagram posted by pcspike is poor quality, but is a 30+ diagram. You can just make out 2N3055 outputs and NPN emitter arrows.
Good advice not to swap the driver boards side to side though and a resistance / transistor junction test round the faulty channel in comparison to the good side will show possible faults for sure.
Old 21st Jul 2022, 1:46 pm   #5
Pcspike
Thanks for that, my next job will be searching for and testing those diodes.
Pcspike is offline
Old 21st Jul 2022, 1:46 pm   #6
Trevor
Yes you are correct I have had my eyes worked on recently ( cataracts) and I don't think they are fully corrected as yet !
Still I would check the output devices first
Trev
Trevor is offline
Old 21st Jul 2022, 2:22 pm   #7
G6ONEDave
G6ONEDave's Avatar
Not checked in the manual but the missing diodes might be mounted on the output transistor heatsink. Mounted there to limit the drive should the heatsink start to heat up, thus hopefully preventing thermal runaway.
Dave
Quote "All is hyperthetical, until it isn't!" (President Laura Roslin, Battlestar Galactica)
G6ONEDave is offline
Old 21st Jul 2022, 2:34 pm   #8
Trevor
These presets are of a very poor quality and are known to go open circuit at the wiper this will blow the fuse even if the transistors are ok check with a multi meter
Trevor is offline
Old 24th Jul 2022, 11:04 pm   #9
Pcspike
Originally Posted by snowman_al View Post
Hi and welcome.
Thanks. Have found the diodes now and they measure ok. Re the 200pf capacitor is this type still available, if so where can i purchase?
Dave
Dave
Thanks Dave, found them now....they were well hidden but measure ok
Hi Trevor, thanks. Will check them out, hopefully tomorrow
Hi Trevor, have checked the pot (In circuit) and seem to measure ok. I agree that they could be of poor quality as well as being very old (but as old as me). I would like to replace them anyway, but looking at the modern ones they seem a lot smaller. Any idea were i could purchase somithing that might do the job?
Dave
Pcspike is offline
Old 25th Jul 2022, 4:29 pm   #10
Pcspike
Hi and welcome.
I disconnected this capacitor today C37 and thought I would give it a try without it in place. I hooked up and played a CD before I switched on the amp so that a source was already in place. The results were good and bad. The good news is that it works as far as I could hear the music (and a low level hum) and it didn't blow a fuse! The bad news is that smoke billowed from the board. I switched off immediately, everything looked OK and found resistor R53 to be hot. It measured OK though.
Had a look on line for a replacement c37 at 200pf but was unsure if what I was looking at was correct, due mainly as I couldn't work out the correct voltage from the circuit diagram.
Would appreciate it you could tell me which I should go for.
Thanks
Pcspike is offline
Old 25th Jul 2022, 8:11 pm   #11
Sideband
Sideband's Avatar
I would think that your C37 is OK. That low value suggests that it is there to prevent parasitic oscillations causing the amplifier to draw excess current and distort. Effectively it stops the amplifier becoming an HF oscillator. You won't hear the oscillation but it can cause distortion and the amplifier will draw excess current. Clearly the capacitor was doing its job so why change it? Just hope it hasn't caused any other damage running without it.
Sideband is offline
Old 26th Jul 2022, 9:27 am   #12
snowman_al
snowman_al's Avatar
I assume you have a meter and can take resistance readings.
As you have C37 'free' (out of circuit) measure the resistance across it. It should be infinite and show O.L on the meter. Any resistance reading, low ohms to 100s of K ohms would be a fail.
As the whole unit has 48 volts on it, from the circuit diagram, so a 63 volt or 100 volt ceramic cap will be fine. (Example https://www.cricklewoodelectronics.c...Capacitor.html ) You will not get an original type today.
Perhaps it is time to build a 'dim bulb tester' / lamp limiter and take some voltage readings round the faulty side.
Old 26th Jul 2022, 1:24 pm   #13
Pcspike
I have no reason to suggest that what you are saying is not correct, how could I, as I have no formal training, this is just my hobby, learning as I go basis thanks to the advice I am receiving here (thanks for your input by the way).
As you have already read, one channel is not working and blowing fuses when powered up. I have found that the two preamp boards are ok, I have tried both of them with the good amp board. I have also tried slotting the good amp board in the other channel slot (though I have since learned that this is not advisable) and found that by doing so the amp itself is working on both channels and that the fault is on this amp board. I have checked every component on it except for the cap directly connected to the P5 pot, so (in my mind), this was highlighted as the culprit, and as you may have seen in my reply to snowman_al, with this cap removed the amp did not blow a fuse and did work of a fashion. I’m going to replace this and see what it does if anything.
With that said, I would really appreciate your input as to how I move forward if the cap change as you suggest is not the fault.
Dave
Pcspike is offline
Old 26th Jul 2022, 1:29 pm   #14
Pcspike
Thumbs up Re: Leak Stereo 30 Plus
Thanks very much for that I really appreciate it, will get some ordered. Yes, I do have a meter that can take resistance readings, and as you say it reads OL a cross the cap. It also measures capacitance from 1 nf to 9999 uf but not pf. I have tried it and it just reads 1.
You could very well be right about dim bulb tester.. something else for me to learn though I am enjoying it.
Pcspike is offline
Old 26th Jul 2022, 1:59 pm   #15
majex45
Are any of these of any use to the OP?
I know some are resistors but I think some are caps (some of the red ones are marked 1K) & others have a colour code.
ID:	261576   Click image for larger version
majex45 is offline
Old 26th Jul 2022, 2:35 pm   #16
Sideband
Sideband's Avatar
They are all ceramic capacitors. 1k is simply another way of saying 1000pF. Others use a colour which essentially is the same as the resistor colour code. Yellow, Purple, Black for instance would be read as 47pF with the brown band as 1%. Sometimes the fourth band is a working voltage....brown 100V, red 200V. This is where you need a data book.
Sideband is offline
Old 26th Jul 2022, 2:58 pm   #17
Pcspike
This is valuable information, I’ve spent a lot of time online trying to figure out how these colours relate to the capacitors. I noticed on the other working board that it does say 200k on the cap, and couldn’t make any sense of it…now I know, thanks
Pcspike is offline
Old 26th Jul 2022, 3:01 pm   #18
Pcspike
Had a close look and none seem to match. Thanks for your offer
Pcspike is offline
Old 26th Jul 2022, 8:27 pm   #19
Sideband
Sideband's Avatar
Some capacitor colour codes seem indecipherable unless you have a data sheet for the particular capacitor. It's also sometimes difficult to know which end to read the colours from. In these cases it helps if you have a test meter capable of reading low value capacitors...say from 10pF up to several hundred uF. You can also buy Chinese component testers that seem quite popular and not expensive. Check out eBay.
Be aware of different ways of writing the same value vis: 103, 10k, 10,000pF, 10nF .01uF, brown, black, orange or perhaps you'll see 102, 1000pF, 1k, 1nF, .001uF, brown, black, red. Then perhaps you might see 152, 1500pF, 1k5, 1n5, .0015uF, brown, green, red... It takes time to get used to all these variations!
102 for instance translates into 1 , 0 and two zero's. 103 translates into 1, 0, and three zero's. Lower case k is simply kilo or 1000 and lower case n is nanofarad.
Some very low value capacitors like 15pF might be marked n15. It pays to try and swat up on these variants.....these are only the most common.....
Note that three numbers can also be found on surface mounted resistors. 105 for instance would be 1 megohm (1 0 00000). On a capacitor it would be 1uF.
Sideband is offline
Old 26th Jul 2022, 9:37 pm   #20
majex45
Sorry I couldn't help. I'll keep looking through the bits & bobs.
majex45 is offline
