Old 2nd Jun 2013, 12:52 am   #21
paulsherwin
paulsherwin's Avatar
Default Re: A problem with my d25 Goblin Teasmade. Please help!
For example, there is a bearing at each end of the motor shaft, and at each end of the gear wheel shafts (real clock people will probably use different terminology). Noise normally comes from something which is rotating quickly.
Go ahead with a proper service if you're reasonably confident though. It isn't especially difficult if you're prepared to put the effort in.
paulsherwin is online now
Old 2nd Jun 2013, 1:05 am   #22
Teasmade
Awesome thanks. I figure with good instructions which I now have and a lot of common sense I will at least be able to tell if I'm doing something horribly wrong and stop and ask for help at that point.
Teasmade is offline
Old 2nd Jun 2013, 8:40 am   #23
Mike Phelan
Mike Phelan's Avatar
I've already sent the OP my (1.9 Mb) document with attached pictures. Thought the pictures would be of interest to others here:
ID:	80412   Click image for larger version
ID:	80413   Click image for larger version
ID:	80414   Click image for larger version
ID:	80415   Click image for larger version
Mike.
Mike Phelan is offline
Old 2nd Jun 2013, 8:42 am   #24
Mike Phelan
And ...
ID:	80417   Click image for larger version
ID:	80418   Click image for larger version
ID:	80419   Click image for larger version
ID:	80420   Click image for larger version
Mike.
Old 2nd Jun 2013, 8:43 am   #25
Mike Phelan
Finally ...
ID:	80422   Click image for larger version
ID:	80423   Click image for larger version
Mike.
Old 2nd Jun 2013, 8:49 am   #26
Mike Phelan
Here's the document as well:
Mike.
Old 2nd Jun 2013, 12:48 pm   #27
Teasmade
Received it Mike and studying the info as we speak! Thanks again
Teasmade is offline
Old 31st Mar 2015, 7:57 am   #28
larry.adar
Default Re: A problem with my D25 Goblin Teasmade. Please help!
Hi - I have had and used a Goblin teasmade model D25 or D25B for years and it has worked perfectly until a few days ago.
I use the clock mostly without the brewing function as an alarm clock, but a few days ago the alarm function failed.
And the alarm time hand no longer remains where I set it and moves slowly round in a clockwise direction. There seems to be no "stop" any more when trying to set the alarm - and it doesn't buzz any more.
I tried opening up the mechanism but decided against opening up the clock mechanism itself without some professional guidance.
I live in Israel - I doubt if I could find any service here.
Anyone any thoughts?
Larry
larry.adar is offline
Old 6th Apr 2015, 5:26 pm   #29
brunel
brunel's Avatar
Mike Phelan, has written a very interesting article on overhauling a D25 clock.
I can't find the original link, but I am attaching the original goblin.pdf
brunel is offline
Old 6th Apr 2015, 7:24 pm   #30
Mike Phelan
Larry,
I'm just closing down but will reply in the morning as it's going to be a fairly easy fix.
Mike.
Old 7th Apr 2015, 8:55 am   #31
Mike Phelan
Right. Looking at my article that brunel has posted, have a close look at the pin on the contrate wheel arbor (P4) and the curved clip (P6) and see if either of these seems to be missing or broken.
The alarm set knob should be fairly stiff; I suspect that over the years the curved clip has become too weak to hold the alarm set wheel stationary and is moving all the time the clock is going.
Let us know how you get on.
Mike.
Old 7th Apr 2015, 2:13 pm   #32
larry.adar
Hello Mike and Frank
Thanks so much for your combined efforts. I have no doubt that I won't be able to get much further than taking the whole thing apart - but that would probably represent the sum total and would result in permanent loss of parts, additional damage and heart-ache.
Are there places where they still do this kind of repair? Where might I reasonably look?
Old 7th Apr 2015, 3:23 pm   #33
paulsherwin
A good traditional watchmaker could service the clock for you, if any still exist in Israel - there are very few left in Britain. Alternatively you could contact a local horology enthusiasts' group for help and advice.
These mechanisms aren't difficult to work on - much easier than a mechanical clock. You just need to be slow and methodical, making lots of notes as you work and storing any removed parts carefully. Take lots of photos with a digital camera.
