Old 17th May 2019, 5:07 am   #1
kkyahoo
Default Wow and Flutter meter
Please note that the National Panasonic VP-7750A is the same as the Topward TWF-533 and the handbook may be found here:
http://www.topward.com/download.htm
The zip is a cal tone for the meter I found on this message board. Download Audacity, put unzipped .ny file into Plug In file in Program Files on Audacity. Run Audacity, the cal tone can be found in the Generate menu, select Loop Play in the Transport menu, connect PC to meter. Press DIN and Lin on front panel meter should read 1%, and display 3000Hz.
Kevin
File Type: zip wow_flutter_cal.zip (414 Bytes, 63 views)
kkyahoo is offline
Old 17th May 2019, 5:44 am   #2
kkyahoo
Default Re: Wow and Flutter meter
Zip courtesy Paul, WD40addict....thanks
https://www.vintage-radio.net/forum/...d.php?t=122895
kkyahoo is offline
Old 17th May 2019, 8:56 am   #3
wd40addict
wd40addict's Avatar
Glad it helped! For those interested in observing actual W&F waveforms don't forget the visualiser here:
https://www.vintage-radio.net/forum/...d.php?t=127882
wd40addict is offline
