7th May 2019, 3:20 pm | #1 |
Simpson 260 Series 6 Multi-meter
Bought this analogue meter at a car boot. Made by the Simpson Electrical Company of Chicago, Illinois, USA.
It works as far as I've tested so far. I've no information on it apart from what is on the meter. It had a 1.5 Volt and quite corroded 9 Volt battery inside it and was rather dirty on the outside. It has cleaned up nicely and on easier inspection now, I'm rather impressed with its ranges. I wonder how it compares with AVO's of similar functionality? One thing that puzzles me though is that for a 10A range there is a -10 A socket and a +10 A socket. Are these the sockets to be used for the 10 A range, as distinct from the common -ve and +ve sockets which are used for most of the other ranges? |
7th May 2019, 4:17 pm | #2 |
Re: Simpson 260 Series 6 Multi-meter
I won't tell you how I discovered that. |
7th May 2019, 4:20 pm | #3 |
If you google "Simpson 260", the first hit is the user manual. I wasn't sure if I could post a link here.
Alan |
7th May 2019, 10:34 pm | #4 |
The Simpson 260 is to the US what the Avo 8 is in the UK, the go to analogue meter similar to use as an Avo but with more sensitive protection as long as the batteries are good.
They are easy to repair and probably easier to calibrate as they have more settings to adjust rather than relying on the integrity of the movement. There is plenty of info on the net including repair info. . Good luck you have a good meter. Chris |
7th May 2019, 11:24 pm | #5 |
The Simpson overload cutout does indeed give much better protection than the AVO cutout, but it’s only fitted to models with a -P suffix, eg a 260-6P, and only works if a good 9V battery is fitted. Otherwise you rely on the fuses.
The 6P is the best 260 to go for, 260-7 onwards replaced the 4mm sockets with recessed 4mm plugs (called “reversed banana jacks” in the USA) and are difficult to get test leads for over here. They are nicely made, but the 10/50/250V range sequence is less good than the AVO 10/25/100/250V sequence. Stuart |
7th May 2019, 11:25 pm | #6 |
Also no weird 15v battery in the Simpson!
8th May 2019, 12:09 am | #7 |
No, but as a result, the mid-scale reading on the highest resistance range is only 120k ohm vs 200k for the AVO. This affects its ability to measure high value resistors.
The highest resistance you can differentiate from an open circuit (but not really measure with any resolution) is about 100x the mid scale value, so 20M ohm for the AVO. This corresponds to a very slight movement of the needle from zero, so the Simpson with its frictionless taut-band movement should manage this despite its lower mid scale value. Stuart |
8th May 2019, 11:11 am | #8 |
Thanks Gents for the info, I've downloaded the instruction manual for the Series 6 model - and Yes, I'm rather pleased with it...
8th May 2019, 5:20 pm | #9 |
Any idea what mine was used for bearing in mind the extra labels on the front, CPV? It is a 260-7P and as you see was made over here. The TTR label implies to me that is was used as a test meter for some specific bit of equipment.
8th May 2019, 6:45 pm | #10 |
Collector peak voltage I think. A probe used for the maintenance of Thorn colour TVs.
9th May 2019, 7:23 am | #11 |
I have a small AVO 73 labelled TTR. Someone suggested it stood for Thorn Television Rentals.
My AVO is modified to have a deeper back and extra flashover protection, so TTR obviously had the buying power to get special versions of testmeters made for them. Your -7P has the distinguishing reset button for the cut-out next to the “Simpson” logo just below the movement, and I see you have two of the reverse banana to 4mm adaptors. Stuart |
23rd Jul 2019, 3:35 am | #12 | |
You have it EXACTLY right, when measuring on the 10 amp scale, you use these jacks (sockets). This shunts the majority of the amps thru a very low resistance and a parallel path to drive the meter. NOTE: 10 amps is plenty so make sure your leads can handle it.. {that SIMPSON260.com site someone else quoted is an excellent resource} As Simpson 260's go, I spent my US Navy career (aka youth) using these.. they are very reliable and rugged... Recently I developed a "hobby" of finding old worn Simpsons and Triplett's, troubleshooting and refurbing them back into good working condition.. Do I sell 'em? NOPE just adding to the collection.... I recently acquired an AVOmeter model 8 mark 2... (thus I stumbled on this forum) I really like how well built and robust it is.. The AVOmeter is 60 years old and I have it working like a champ!! |
27th Jul 2019, 12:02 pm | #13 |
Thank you joendoodle for the information on the -10, +10 Amp range. The Simpson is now my 'go to' analogue meter for things my small Avo can't do well.
Oh, and welcome to the forum ! |
27th Jul 2019, 2:56 pm | #14 |
joendoodle, welcome, if your Avo Model 8 ever malfunctions again, much of the information to fix the usual problems is either within these walls, or accessible from within these walls.
I have a 9-0-9 vehicle Ammeter made in NY that is also very far from home and of obscure origin. It's calibrated to read in a horizontal position so we think it's from a motorcycle or tractor, and looks pre-war. (Needless to say it's works and it's accurate!) Dave |
