Old 1st May 2019, 2:50 pm   #1
mikko rintala
Default How to measurement iA avo ct160 tube tester
Mikko hi. I wonder how to measurement iA exsamble EL84 tubes? Avo mk4 show it right now but how Avo ct 160 show it?
mikko rintala is offline
Old 1st May 2019, 2:57 pm   #2
Station X
Station X's Avatar
Default Re: How to measurement iA avo ct160 tube tester
Just go through the normal test procedure first selecting a suitable grid bias voltage and then making no further adjustment to the grid voltage. Once the meter is zeroed (bridge balanced) read the current from the anode current control scales. These controls have no effect on the actual anode current, they just enable it to be measured.
Graham. Forum Moderator
Station X is offline
Old 1st May 2019, 8:59 pm   #3
mikko rintala
Ou jee of course. Now i am much happy.
Thank s
Best Regaird Mikko
Old 3rd May 2019, 11:17 am   #4
John_BS
John_BS's Avatar
If you want to double check your result, remove the Anode 1 link and substitute a mA meter. It will read half the actual anode current
John
John_BS is offline
Old 4th May 2019, 7:11 am   #5
mikko rintala
Hi. If i use that anode link, is upper or lower link +ve?
Best regaird Mikko
Old 4th May 2019, 10:31 am   #6
John_BS
John_BS's Avatar
On mine it's wired with +ve closest to the hinge, -ve adjacent to the selector switch.
John
John_BS is offline
