Old 20th Sep 2014, 12:02 pm   #1
John_BS
John_BS's Avatar
Default Collet sizing; can you help?
I've aquired an obsolete "Dremel-like" cordless mini-drill made by Ryobi (HTC 18). I'd like to buy a set of collets but can't find any information on the OD dimensions of current OEM types available (i.e. the OD of the long cylindrical section which is not slit). The Ryobi collet is about 4.2mm; could someone with a Dremel or similar measure one?
Many thanks
John
John_BS is offline
Old 20th Sep 2014, 1:46 pm   #2
60 oldjohn
Default Re: Collet sizing; can you help?
No Dremel, but my Black & Decker Wizard is around 4.3mm D.
John.
60 oldjohn is offline
Old 20th Sep 2014, 2:39 pm   #3
John_BS
John_BS's Avatar
Thanks John, sounds like there may be some generic standard.
John_BS is offline
