Old 17th Sep 2014, 3:40 pm   #1
WaveyDipole
WaveyDipole's Avatar
Default Weller PU81 failure
Unfortunately, my Weller PU81 soldering station has failed. I was doung a routing job on an amp (which was powered off and unplugged) when I touched the positive rail of the circuit and a discharge from the soothing capacitors arced across to the iron tip.
For some reason my solder station is now inoperative- no LEd light and no heat. I'm a bit puzzled since the tip of the iron is connected directly to earth and to electical earth at the plug. It does not appear to connect to the control circuit in any way. There is no short within the iron itelf so no way for the charge to have done any harm, yet it seems to have done.
The fuse is OK, I am getting voltage to the transformer and 25v out of the transformer to the control board. I can't find any obvious fault at this time, but clearly something has failed.
Can anyone offer any suggestions? Do I need a new board or is this repairable?
WaveyDipole is offline
Old 17th Sep 2014, 3:46 pm   #2
WaveyDipole
Default Re: Weller PU81 failure
Ok, this is weird. I put it all back together again and its now working. Did absolutely nothing other than checked voltages and for loose connectors, but again, nothing obvious.
I'm glad its working again though! It represents a considerable investment!
