1st Aug 2014, 1:19 am | #1 |
Taylor 45b/45c Valve Chart - Searchable PDF
Hi, I recently purchaced a Windsor 45b. I like it very much. So much so that I just won an auction for a 45c!
I downloaded the 45c valve chart in PDF format. I'm lucky enough to have Acrobat Pro which has a text recognition tool built in. It's very accurate and makes searching for valve types/settings a little less time consuming. Especially when searching multiple valves and you don't ave a hard copy of the chart. Anyway, here's the link If anyone would like this done to any particular PDF they may have, I'd be more than happy to oblige. |
1st Aug 2014, 9:11 am | #2 |
Re: Taylor 45b/45c Valve Chart - Searchable PDF
Thanks for posting the chart Pete, it works very well
I prefer to use my Taylor 47A over my Avo twin panel tester, I would like a 45C when funds allow. Mark |
1st Aug 2014, 6:14 pm | #3 |
No problem. I hope it makes life a little easier
2nd Aug 2014, 3:19 pm | #4 |
Many thanks for uploading the 45C data, I use my C regularly and the search facility will be really useful.
Cheers Roger |
7th Sep 2014, 9:41 am | #6 |
Excellent!
Thanks Craig |
8th Sep 2014, 5:58 pm | #7 |
No problem!
