20th Sep 2014, 12:02 pm | #1 |
Collet sizing; can you help?
I've aquired an obsolete "Dremel-like" cordless mini-drill made by Ryobi (HTC 18). I'd like to buy a set of collets but can't find any information on the OD dimensions of current OEM types available (i.e. the OD of the long cylindrical section which is not slit). The Ryobi collet is about 4.2mm; could someone with a Dremel or similar measure one?
Many thanks John |
20th Sep 2014, 1:46 pm | #2 |
Re: Collet sizing; can you help?
No Dremel, but my Black & Decker Wizard is around 4.3mm D.
John. |
20th Sep 2014, 2:39 pm | #3 |
Thanks John, sounds like there may be some generic standard.
