Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps. |
#1 |
This is for a Philips 940 trf radio the HF coil/tx is o/c the service manual gives it at 15k ohm .
#2 |
I suspect that the original will be very hard to find, but I'd guess from the circuit (a larger area of the circuit would be helpful) that it's a combined anode resistor and radio frequency choke (RFC).
If that guess is correct, then wiring in a 15k resistor is series with a 2.5mH inductor might get things going. There's hardly any current flowing so a miniature inductor will cost next to nothing. Hopefully, others could confirm? B
Data beats opinions most times... that's my opinion, though I have no data on that. |
#3 |
Thanks Bazz yes it is the ht and rf choke ,feed to the detector ,I have it working using a interstage tx , I noticed different coils alter the audio quality, the original is in the freezer, I have always heated the capacitor blocks to remove the innards ,a bit messy though , Mick.
#4 |
How does the freezer help put?
B
#5 |
Hi, freezer is a good way to be able to remove pitch as it makes it very brittle. It can still fly everywhere when chipped off though.
A choke and / or resistor were my thoughts as well but not enought schematic visible to be certain. Within reason the choke can be as large as you like (economics probably dictated its size in production). Then adjust series resistor to get voltages correct, consistent with reasonable sound. In use the choke may even have been wound with resistance wire . Ed |
#6 |
There is nothing to be gained by showing more of the cct ,HT is fed to the bottom of the choke, one of my jobs today will to remove the choke from pitch filled box, and hope the break is accessible , well ! you never know,
#7 |
Hi Mick, I may have some suitable chokes if you need one. The old style wound as several "piles" will probably work fine
Ed |
#8 |
Hi Ed ,I have the set working using a push/pull driver tx secondary windings, the two coils in series gives 11.6k I have had the tx a long time ,something tells me if I fit it I will need one in the near future, so I would be interested in your offer can you let me know the dimensions please as I would like it to fit in the original place. Mick.
#9 |
Hi Mick if you can post a picture when extracted and approx size I'll see what in my collection matches up.
Any idea of its max current rating? Ed |
#10 |
Hi Ed to fit inside the original screened box it needs to be 53mmx 43mm x40 mm, otherwise 65mmx 50mmx 55mm then I will have to make a box for it , thanks ,ps current les than 1ma about 0.75ma Mick.
#11 |
Hi Mick, 2 types here as shown below, both about 40mm long and 15 dia
The one out of the can has fixing bolts and is 120R, the wire ended one is 12R Yours for the postage Ed |
#12 |
Hi Ed thanks for that but I think it needs to have some iron in it ,I tried something similar to what you have there, didn't work. Mick.
#13 |
Picture of the choke, the wire is very thin 0.06mm Mick.
