Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Old 19th Jan 2021, 3:29 pm   #1
DMcMahon
DMcMahon's Avatar
Default 6AR5 Valve Wanted
Looking to purchase a 6AR5 or equivalent output pentode valve.
DMcMahon is offline
Old 19th Jan 2021, 3:38 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: 6AR5 Valve Wanted
Not many of those about. You should be able to sub a 6AQ5/EL90 with a small wiring change.
paulsherwin is online now
Old 19th Jan 2021, 3:43 pm   #3
DMcMahon
DMcMahon's Avatar
Thank you Paul, I am pretty sure I have no 6AR5 or 6AQ5 anywhere, need to double check if I have any EL90.
DMcMahon is offline
Old 19th Jan 2021, 3:58 pm   #4
usradcoll1
The Knight-Kit Star Roamer receiver kit called for a 6AR5 or a 6AK6, no changes.
usradcoll1 is offline
Old 19th Jan 2021, 4:02 pm   #5
Ed_Dinning
Hi David, I may have some EL90's if you are stuck; there might even be a 6AR5 in some recess. Give me a couple of days to look
Ed
Ed_Dinning is offline
Old 19th Jan 2021, 4:12 pm   #6
DMcMahon
DMcMahon's Avatar
Thank you Ed, there is no rush.
DMcMahon is offline
Old 19th Jan 2021, 4:13 pm   #7
DMcMahon
DMcMahon's Avatar
Thank you.
DMcMahon is offline
Old 19th Jan 2021, 4:59 pm   #8
Orakle42
The Lafayette KT320 used a 6AQ5 as the .audio output. I modified my KT320 to use a solid state OP stage some time ago but I still have the Matsushita 6AQ5.
Its on my desk in front of me if you are interested. It was working fine when I pulled it.
PM if interested.
Orakle42
Orakle42 is offline
Old 19th Jan 2021, 5:30 pm   #9
DMcMahon
DMcMahon's Avatar
PM on its way.
DMcMahon is offline
Old 19th Jan 2021, 7:43 pm   #10
DMcMahon
DMcMahon's Avatar
Now will be getting one from orakle42 so the Thread can now be closed thank you.
DMcMahon is offline
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright ©2002 - 2021, Paul Stenning.
