Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps. |
#1 |
After 2 acorn valveholders for 5+2 pin valves. Specifically the 954 type.
Any state considered. Have worked out how to make them, but its a bit of a faff. |
#2 |
Trying to be helpful, do you know that the originals have a bit of a reputation for being hard to work with? There was a significant mortality rate getting valves in or out of them.
The pins are made of an alloys that will take tin-lead solder quite happily; I practiced on some 954's that were already bust. I have one project on my "to do" list with a 954, and that will not make use of a holder! B
Data beats opinions most times... that's my opinion, though I have no data on that. |
#3 |
Some of the smaller crimp sockets are a neat fit on these pins, If soldered (no crimpers needed) and sleeved the are a neat fit onto the valve pins without any thermal or mechanical stress. The valve can be supported in a large rubber grommet
Ed |
#4 | |
![]() Quote:
I'm thinking about placing the Acorn in a hole on a PCB such that its pins are just above the board and connecting them by wires of ~5mm through the board. Very interesting valves! B
#5 |
Thanks all. Using crimpers or some sort of tubular connector seems a good idea. I have tried with a ring of paxolin and clips made from opposite springs from a 0.15" edge connector. That seems to work OK - but a bit of a faf.
#6 |
Good morning
If you still want Acorn valve holders.I have a pair of Bulgin British " micro loss" unused you can have for £5. I am interested to know wat your project is. Derek G0VDV |
#7 |
Hi Derek,
I would be interested in those. Send a PM with the Ts&Cs. The project is a Jason-type FM tuner using the acorns in the front end and some wire ended EF91 types I picked up. And home-wound IF transformers. I have some proper EF91s for the audio amplifier. Slight concern that the acorns/EF91 might be a bit marginal on gain - but a cheap MMIC pre-amp might solve that. Rgrds |
#8 |
I've used chopped up choc block connectors for powering odd valves.
Andy.
#9 |
It would be good if someone could post a picture of the British Acorn bases; are they significantly different from the more common US ones?
B
#10 |
I'm not sure how I came by my Acorns and their holders , but I do remember using them in the 1950s . Identity unknown but reading clockwise from the heater pins the hard-to-see legends are :-
CFK 49376 F Hope this helps . Laurie . P.S. They may (just possibly) have come from Mr. Field's emporium in Nantwich . |
#11 |
Thanks for that picture Laurie. I think the CFK ones are the American ones I've seen pictures of before. I wonder if the Bulgin ones are the same or different?
B
#12 |
Consider using individual socket pins from a 7 or 9 pin valve socket.
Hold the 954 body in some form of grommet or similar. Have used this method in making a GDO in the late 1950s. It is very gentle on the glass to pin area. |
#13 |
One in stock at Mullard Magic:
https://mullard.org/collections/comp...6-acorn-valves Neat homebrew Acorn Valveholder by forum member Bob, 'Variometer', (a retired Ships' Radio Officer), sadly not active on the forum for more than three years now: https://vintage-radio.net/forum/showthread.php?t=29222 Acorn TRF by the same member with a coil inside and upturned Humbrol modelling paint tin: https://www.vintage-radio.net/forum/...d.php?p=187084 The 'Acorn 1' receiver finished: https://www.vintage-radio.net/forum/...079#post187079 A couple of other items that might interest - the first from a BVWS Bulletin: Page 8 – ‘A Boyhood Ambition’ – RCS Kit repro: https://www.bvws.org.uk/publications...letin_28_1.pdf RCS Kit: http://vintageradio.me.uk/kits/rcsport.htm There - lots of lockdown fun to be going on with!
#14 |
This is my GDO project which is under construction. The Acorn will be the last thing to be connected, and the picture shows a defunct one in place just for illustration. The aim was to keep the (soldered) connections fairly short.
B
#15 |
Thanks all. I am going with Derek's kind offer. Will find out whether Bulgin fits.....
I got an acorn based kit shortwave set way back. Worked pretty well. will see if my new finds still operate. Like the GDO very much. |
