Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps. |
#1 |
A friend's Crate B80XL is cutting out after about 40 minutes playing. After a cct diagram, please.
Cheers, Frank |
#2 |
I cannot help you to the schematic...sorry
I have just this tip that perhaps might help you Did you control all the welding points and connectors ? As I have been told, these are often little common faillures of (older)Crate amp's succes ! BR Ben |
#3 |
I haven't had any success from the usual sources either, Ben. I haven't received the amp yet, so I guess that's all I can do; inspect, give it a signal then poke and prod, fiddle and wiggle. It would be much nicer to do things properly with the sig gen and scope!
Cheers, Frank |
#4 |
Hi Frank
You may find someone able to help on here: https://www.thefretboard.co.uk/ I am a member so if you don't want to join just to ask about the schematic I could do a post for you. Martin
Is it live, or is it... no, it's live actually... |
#5 |
Thanks for that, Martin. I've signed up on the off chance!
