Old 23rd Feb 2020, 11:48 pm   #1
tracypaper
tracypaper's Avatar
Default Hacker Gondolier help please.
While sorting deck problems on the above player a pick up wire has snapped off the rear panel that the add on amp plugs into, the pick up wire in question does not have the earth shield wire attached to the rear outputs only the central blue plastic covered live is attached. Can any body supply a picture to help me re-attach please?
Cheers.
Gaz.
tracypaper is offline
Old 24th Feb 2020, 9:34 pm   #2
Radio tirana
Radio tirana's Avatar
Default Re: Hacker Gondolier help please.
Hi Gaz
I have attached a photo of the phono socket panel from a Cavalier I suspect it's the same or very similar. The earth screens are sleeved and connect to the left hand fixing screws both of which have a solder tag between the fixing screw and the paxolin panel the two solder tags are joined together with tinned copper wire.
Hope this helps. Kind regards, RT.
Radio tirana is offline
Old 26th Feb 2020, 11:33 pm   #3
tracypaper
tracypaper's Avatar
Cheers RT, that's just what I want.
Gaz.
