Old 26th May 2020, 12:28 pm   #1
nighthunter
Default Electrolytic caps for homebrew valve sets
Hiya
I'm going to attempt some homebrew valve receivers - both low voltage and higher voltage - 250V, built as prototypes.
Being a bit OCD, I like to have a selection of components available rather than buying them individually as needed and waiting for them to arrive - by which time Im usually distracted by another project!!
Before I go on an online spending spree, can you suggest the most common electrolytic capacitors used in basic valve receivers? I will then purchase 2 to 3 of each value so they are available when needed. e.g. 10u, 22u, 47u, 220u, 330u, 470u at 350V to 500V- am I missing any or is this sufficient/too many?
I'm not planning on following any design in particular, just base it on some of the earlier SPRAT articles using some of the surplus triode/pentode valves I have.
Steve
nighthunter is offline
Old 26th May 2020, 2:14 pm   #2
Silicon
Default Re: Electrolytic caps for homebrew valve sets
10uF, 22uF and 47uF will cover most requirements.
Silicon is offline
Old 26th May 2020, 4:04 pm   #3
25v or so for cathode decouplers for audio output stages, and the rest rated comfortably above your intended HT.
Most radios don't need many electrolytic capacitors... a reservoir, a smoother and a cathode decoupler.
Radio Wrangler is offline
Old 26th May 2020, 4:12 pm   #4
G4_Pete
I would also reccomend storing the capacitors with Value/Voltage AND the ripple rating.
Pete
G4_Pete is offline
