8th May 2020, 8:47 pm | #41 |
Re: Akai 4000D arrived today
Excellent job on the heads Garry and well done with the Reel Table clutch adjustments.
8th May 2020, 9:06 pm | #42 | |
When I was looking at the heads, I thought to myself "I bet I can guess which one is the left channel!" |
8th May 2020, 9:14 pm | #43 | |
One thing I noticed is that when you pull the mono switch out, it doesn't combine the stereo inputs together, so I may make a modification with an extra switch to give that option. Do you know what size the threads are for the front panel screws? I tried a 3mm and it was too big. Measuring an original screw it was 2.85mm, so it might be an imperial thread size. Cheers |
14th May 2020, 11:08 pm | #44 |
I put it all back together the other day, had a couple of hours out of it, then the right hand channel on stereo stopped recording. It erases but doesn't record.
In the various mono settings the right hand side records via the left channel circuits, so it's most likely a fault on the right hand record pcb. Does anyone know of any common faults to look out for? I need to open it up again soon anyway; The feed clutch could do with tightening up a tad, and the take up clutch has a regular squeak each revolution when in PLAY. |
14th May 2020, 11:29 pm | #45 |
Could be the 2SC458LG transistors on these, notorious for going noisy, I have the GX4000 version and changed them in the amplifier section, try a google search for akai 4000 noisy transistors, various links, including some to this site, equivalents are available, also the selector switches need a good servisol clean.
14th May 2020, 11:43 pm | #46 |
I've already cleaned all the switches with servisol, so I'll swap the left and right boards around and see if the problem moves across.
Cheers |
16th May 2020, 9:07 am | #47 |
Are there separate left and right boards in the 4000D ?
16th May 2020, 9:48 am | #48 |
Yes, there are four small boards; play back right, record right, and the same for the left. They're in a vertical side section, and pull out on edge connectors.
I swapped the right and left record boards and the problem moved over to the left, so the right channel board is knackered. I've ordered two refurbished record boards from ebay for 20 quid posted. I'll put those in and can compare the other two as a fault finding excercise, and probably put new transistors in. |
16th May 2020, 9:59 am | #49 |
That is good. Have never had to look at mine in the 4000D. I think all the other 4000 series have the one main Pre-Amp board, so the 4 separate boards is like some of the later Akai's.
I can now actually see the 4 boards in the 4000D schematic as attached. |
16th May 2020, 10:17 am | #50 |
I obviously have looked at mine because I have photos ! memory !
16th May 2020, 10:23 am | #51 |
There's a much better quality scan of the diagram on the net, should you ever need it. It's at the end of the user manual on hifi engine.
https://www.hifiengine.com/manual_li...ai/4000d.shtml |
16th May 2020, 10:26 am | #52 |
16th May 2020, 7:21 pm | #53 |
Yes I have the User Manual scan, just attached the other schematic because it is not cut into 2.
