7th Jun 2020, 11:41 am | #61 |
Re: Grundig TK245 overhaul
Do not really know about the ghost recordings, possibly may be print through from another track.
Normally it is not necessary to test heads for continuity, the only time one might want to do it, is if recording/playback/erase does not work at all and after other diagnostics yield no clues, then checking the respective head (s) to make sure not open circuit is then useful. Some service manuals will state a DC resistance value or an AC impedance (at a particular frequency) for the various heads, would not pay too much attention to the stated values verses the actual measured values, the most important thing is not being open circuit. Some people may advise/warn against doing this but normally there should be no risk especially if using a digital test meter. There is the risk of possibly magnetizing the head which may affect sound quality but I have never experienced this and using a head de-magnetizer post head continuity checks would address that possibility. |
7th Jun 2020, 11:56 am | #62 | |
7th Jun 2020, 12:05 pm | #63 |
All the belts and 'wheels' are original in my Grundig, though I cleaned their working surfaces with thinners to remove any glossy coatings (maybe this was 'naughty'?) and the spooling and take-up are now working fine.
Steve
https://www.radiocraft.co.uk |
