Reply
Old 25th Sep 2023, 11:22 pm   #1
thermion
Default Solartron srs 153s
Picked up this power supply on sunday from hack green rally, after curing a
Few silly faults its working.. sort of.. thing is i can’t turn the output voltage down to zero. Tested everything in the negative bias circuit, changed a couple resistors
That had gone high, & checked all the caps, but i still cant get it to turn down
To zero. The only thing i can think of are the two 5b/254’s in output are passing grid current & pulling the bias down. Removing one output valve at a time does reduce the minimum voltage quite a bit. They are connected in paralell..
It says 0-500v on the front panel so am i right in assuming it actually is suppoosed to go to zero?
thermion is offline   Reply With Quote
Old 26th Sep 2023, 1:34 pm   #2
Dave757
Default Re: Solartron srs 153s
Hi
The manual says 0-500volts, so that's my assumption too!
Kind regards
Dave
Dave757 is offline   Reply With Quote
Reply
