Reply
Old 16th Jul 2023, 8:29 pm   #1
sparkymike
Default Linco Converser
Anyone know what this bit of equipment is used for ?
I am having a sort out here and have no idea where this came from.
The only photo on the net I could find was on an auction site and this was bundled with an A10 canopy and set tester.
An intercom set ?
Mike.
ID:	281448   Click image for larger version
sparkymike is online now   Reply With Quote
Old 16th Jul 2023, 10:12 pm   #2
Station X
Station X's Avatar
Default Re: Linco Converser
Something connected with Lincompex?
Graham. Forum Moderator
Station X is online now   Reply With Quote
Old 17th Jul 2023, 6:37 am   #3
sparkymike
On the auction site it was listed under tractors, so could it be some kind of intercom between farm and driver. The equipment in the photo beside it on that site looked to be much too complex for any kind of tractor in my mind, but I could well be wrong.
Possibly a tank intercom. They can be very noisy.
I will try and post a link to the auction site..
Mike.
Old 17th Jul 2023, 6:41 am   #4
sparkymike
Link for above details.
Mike.
http://https://www.proxibid.com/loti...uator-test-set
Old 17th Jul 2023, 6:53 am   #5
sparkymike
Link does not work for me but Auction photo posted below. Auction site is in AZ. USA, so the A10 connection ,mentioned on the site, could be the A10 ''Warthog'' .
Old 17th Jul 2023, 10:35 pm   #6
Graham G3ZVT
Graham G3ZVT's Avatar
I fixed SparkyMike's link
https://www.proxibid.com/lotinformat...uator-test-set
One of the images shows the makers nameplate "Leyton Instrument Co. Ltd"
I found this from 1968
Instruments for audiology and education of deaf; hearing aids; instruments for psychoacoustics. Agency and direct purchase. Leyton Instrument Co. Ltd. (Importer exporter distributer), 54 Albert Road., Caversham, Reading, Berkshire.
https://www.google.co.uk/books/editi...sec=frontcover
Graham.
G3ZVT
Graham G3ZVT is online now   Reply With Quote
Old 21st Jul 2023, 1:53 pm   #7
Malcolm G6ANZ
Malcolm G6ANZ's Avatar
Audiology equipment has the headphones coloured red and blue for left and right. Given that its called a 'converser' it could be a simple mic amplifier to drive headphones. In use possibly to determine how much amplification is needed for each ear. There are two, what look like, power amp transistors with heatsinks on the top left of the PCB.
Malcolm
Malcolm G6ANZ is offline   Reply With Quote
Old 22nd Jul 2023, 7:45 am   #8
sparkymike
If in the auction, it was a part of the other USAF equipment, then it could have been used for an engineer to converse with another engineer , or pilot, in the cockpit. If I can read any of the transistor part numbers that could tell where is was made. Just curious. Pity it did not arrive with the other item in the link photos. Now that would be interesting.
Mike.
Old 22nd Jul 2023, 7:04 pm   #9
Malcolm G6ANZ
Most auction sites lump anything vaguely technical together so its not surprising that this is with other unrelated stuff. From the construction I would say it has nothing to do with aviation or military as the quality is not good enough for either of these sectors. Its probably made by a small company for a unique purpose related to audiology. I suggest that its not an intercom as its construction lends itself to be used on a bench and not in a vehicle. So an a hearing aid test set or similar.
Old 23rd Jul 2023, 12:30 am   #10
Graham G3ZVT
I'm convinced you're right Malcolm because of the company details I found, plus the red and green labels on the volume controls that you pointed out.
I can imagine it being used in a classroom situation.
We've come a long way though, I was privileged to meet a profoundly deaf girl aged about 4, her mother wore a discreet mic on a head band, and could transmit her voice to the girl's hearing aids even if she was out of sight in another room.
Graham.
G3ZVT
Reply
