Reply
Old 22nd Jun 2023, 11:05 am   #1
Antikeppi
Default Wiring up 2 old (different) intercom, help
Hi! I’m connecting 2 identical intercoms, but they use different abbreviations. In 1 it uses L,EK,MZ,WZ, and the other one it uses L, MC, C, and ZC. I don’t know how to connect them. I’m using 9V batteries to connect them. For now I’m connecting the L cables together with 1 9v battery. But if I connect them, 1 intercom starts with ringing. Idk how to properly connect them. I have L connect with battery and then connected to the other L; EK with ZC; WZ with C; and MZ with MC. Can anyone tell me what those abbreviations mean? And tell me which cable with should be connected with the battery? Thanks
Antikeppi is offline   Reply With Quote
Old 22nd Jun 2023, 2:26 pm   #2
russell_w_b
russell_w_b's Avatar
Default Re: Wiring up 2 old (different) intercom, help
I think C and Z stand for Carbon and Zinc: positive and negative battery connections in other words. E might be Earth Return and L line. Earth can be replaced with another line wire. I’ll check when I’m back home in front of a book.
Regds,
Russell W. B.
G4YLI.
russell_w_b is offline   Reply With Quote
Old 22nd Jun 2023, 3:08 pm   #3
Antikeppi
Hi! Thanks, but I did a small error, it’s not ZC but ZT, in 1 intercom there are the following abbreviations; ZT,C,MC,L
The other; EK,WZ,MZ,L
Sorry I wasn’t home and I had to guess
Old 22nd Jun 2023, 5:57 pm   #4
Roger Ramjet
Photo's would help Andy...
Rog
Roger Ramjet is offline   Reply With Quote
Old 22nd Jun 2023, 6:37 pm   #5
russell_w_b
* ZE = Zinc and Earth (meaning negative of battery and earth return).
* C = Carbon (positive of battery).
* MC = Microphone carbon (one side of the microphone).
* L = Line.
Those are the 'English' terminal markings. Beyond that, different manufacturers have different nomenclature! It would be wrong to guess but you're unlikely to damage anything if mis-connected, other than perhaps inadvertently short out a battery.
Like Roger says, a pic would be good.
Regds,
Russell W. B.
G4YLI.
Old 22nd Jun 2023, 6:42 pm   #6
Antikeppi
Sure, here they are, ill add 1 more
ID:	280186   Click image for larger version
ID:	280187   Click image for larger version
ID:	280188   Click image for larger version
ID:	280189   Click image for larger version
Old 22nd Jun 2023, 6:42 pm   #7
Antikeppi
here is the last one
Old 22nd Jun 2023, 7:06 pm   #8
Antikeppi
* L = Line.
Thanks! But I’m wondering, which “station” to which station, should be connected to? Because I have 2 different intercoms, identical, but they use different abbreviations, if I connect C and ZT to the battery, where should I connect the “WZ” (Wecker = ringer) from the other intercom?
Old 22nd Jun 2023, 7:36 pm   #9
Roger Ramjet
Nice looking units Andy,
It looks like the terminal blocks are later add on. At the mo it is guesswork but if the units were wired as suggested in your previous post then two terminals would be for the battery noting one would reverse polarity to the other.
The other two wires would be for the line.
I would start again & rewire rather than faff about with existing. Easy to sort on the bench.... pity you are not local.
Rog
Old 22nd Jun 2023, 7:57 pm   #10
Antikeppi
Rog
I connected C and ZT to the battery, and the 2 L's together. I still miss EK and WZ , where should I connect them? Im new in these type of stuff, if u could make me a little scheme of what should be connected to, it would be fantastic.
Old 23rd Jun 2023, 7:51 am   #11
dagskarlsen
dagskarlsen's Avatar
Not sure what you have of tools and instuments, so here is the without anything way of testing:
Use a 9V battery and test the termiansls until you hear a loud click in the receiver, then hold the hook switch in on hook position and test the same 2 terminals. The ringer should ring, and you have identified the line terminals. Do the same on the other phone, and connect them together. Battery to the other 2 terminals, and you should hear the sound in both phones. (Z is negative ) normal voltage would be 3-4.5 V. Looks like these phones not polarity dependent, but if you not get the wanted effect try to reverse polarity on one phone, and only one.
dagskarlsen is offline   Reply With Quote
Old 23rd Jun 2023, 8:11 am   #12
Antikeppi
I'll try this when ill come home, but im wondering; if I found the 2 terminals for each phone, the other 2 terminals should be connected to the other 2 terminals of the phone right? I mean, if I have found the "battery" terminals, ill have 2 terminals on 1 phone and other 2 terminals on the other phone, should those be connected together or they also need to be connected to a battery?
Old 23rd Jun 2023, 11:06 am   #13
Roger Ramjet
Absolutely spot on advice !
Battery polarity won't affect the buzzer calling but may stop speech if the telephony components are series connected.... in which case one battery would need to be reversed to mitigate the counter emf effect.
Old 30th Jun 2023, 5:24 pm   #14
Antikeppi
Ok I have found the line lines in each phone, what should I do next? Should I just connect the other 2 cables on the battery?
Old 30th Jun 2023, 6:18 pm   #15
Roger Ramjet
Yes worth a try..... as above, if no speech then try reversing polarity on one of the batteries.
Reply
