#1 |
Hello. I have a Dinosaur Designs Standards Converter and Test Card Generator. In the latter I only have Test Card F. I would like to add other test cards, particularly "C". Does anyone know if the EPROMs, or the binaries for them are still available? I can read and program EPROMs so just the binaries would be useful.
Thanks Colin |
#2 |
I'd get in touch with David Grant (the designer) if I were you via www.murphy-radio.co.uk
#3 |
As a follow-up to the above post, I contacted Dave earlier and this was his response:
"Colour testcard generators require modification to produce monochrome (625-line only) images'. They will need to be RTB but I can still do it." |
#4 | |
![]() Quote:
#5 |
Thank you, I'll do that when I get home at the weekend.
#6 |
#7 |
Thank you. Looking through my paperwork it seems that my generator has already been modified by Dave as it also has a monochrome test card (TCC) EPROM pair in it which works ok. I have messaged Dave as you suggested.
#8 |
Could these EPROM images be posted for the benefit of other Members please?
Chris Williams
#9 |
The moderators have been advised that the EPROM images are copyrighted and cannot be shared on these forums.
THREAD CLOSED Please don't attempt to resurrect this discussion.
