#1 |
Hi peeps.. Not my usual field of interest. Some of you may be interested.
As mentioned in the Items for Sale, I purchased 3 Marconi Test pieces, from a vendor on FB Marketplace, As the photo's on the ad were not good, with fingers crossed, hoping it may be of use to my RF interests, I bought the items. Delivered to my door in under an hour. I was slightly disappointed that it was Telecom based and not RF test gear. The stand alone item is / was built like the proverbial "outhouse" VERY Heavy, case must weigh a few Kg's. It has 3 highly populated pcb's mostly TTL and 2 X FPGA's I have not ventured into the other two items yet, but are also very heavy and in a case offering rack mount . If anyone has any ideas regarding "worth" "Value" technically, I could be persuaded to part with the two rack mounted items. If not I will attack with vigour and lekky screwdriver. Please see photo's attached
Should get out more. Regards Wendy G8BZY |
#2 |
BERTs Bit error ratio testers. They can also count raw errors and likely do statistics on errored minutes and error-free minutes, that sort of thing. The first box likely only does 2048 kBit/sec primary rate. The second box says it does 140MBit/sec and some intermediary PCM levels. If memory serves me, that 140MBit/sec is probably the 139.264 Mbit/sec pleisiochronous data hierarchy in Europe.
THere isn't much that will interest you inside. It looks like you've bought a couple of boxes, knobs, power supplies that something usedful could be built into. David
#3 |
Theres a few "nick nacks" in the stand alone item, a few SMA connectors with good grade coax, might even fire up the hot air gun.. a SMPsu +12v, +5V and -24V. It was worth £30 just to see what was in them. + A pair of moving coil meters, my knobs box will be more full too
#4 |
Note that the grey knobs are similar to / same as those used on vintage Neve recording equipment. If you put 'Neve knobs' into Google, you'll see what I mean. There are replicas made by several firms, such is their desirability for DIY projects. The originals could fetch a few quid, if you bear in mind that a complete mixing console from this era will cost you about as much as a family house now.
edit - if you decide there isn't much of interest to your hobby in there, it could be worth offering them to a firm who rents film props out. |
#5 |
Hi Knob twiddler. Before I saw your post "just now"..... the items have been dismantled and the useful bits stored, but thanks for the idea
