#1 |
Just recently been given this wee buzzer/induction coil Tester(I assume). A pal thought it was just a wee "Electric Therapy Machine", but the manufacturers label indicates a possible testing function.
I've taken its picture alongside my Victorian Therapy apparatus(lhs) and a later Edwardian one(rhs) The label says :- Manufactured by "The Consolidated Telephone Construction & Maintenance Co. Ltd." Farrington Rd, London EC Size = 5.5" x 3.5" x 4" high. Any info most appreciated. Regards, David |
#2 |
Possibly an induction coil to generate 25Hz ringing current, or it may be an insulation tester. The lack of any form of meter probably rules out the latter suggestion.
#3 |
Not directly relevant, but there is some information about the manufacturer here: https://www.vintage-radio.net/forum/...d.php?t=122398
Bill, BVWS member |
#4 |
A couple of press clippings that might be of interest.
All was not well at Consolidated at the start of the new century ![]()
-- Graham. G3ZVT Last edited by Graham G3ZVT; 13th Apr 2023 at 12:01 am. |
#5 |
David, I think this is part of a telephone, and not a testing device.
Rather than a rotory magneto to crank, you seem to have a cylindrical magnet that you pull-push to ring the bell of the other instrument. Then again, maybe it's only for signaling, perhaps for railway use.
-- Graham. G3ZVT |
#6 |
The medical coil on the left is similar to others made by Ludwig Schulmeister. I have one myself, although mine has no manufacturer's mark.
Beautiful things. Tony |
#7 | |
![]() Quote:
I'm guessing a variable voltage insulation or flashover testing device, and there may have been an instruction on how far in the core is pushed to achieve a certain voltage. Just because a telephone company manufactured it doesn't mean it was for telephone use. The Beethoven Mk:II shot-firing exploder contains an ALINCO hand-magneto as found in contemporary field and other Bakelite telephones as an example of telephone manufacturers farming out products.
Regds, Russell W. B. G4YLI. |
#8 |
Thanks Guys for all the info on the company. The adjustable tubular insert is chromed brass which shields the inner iron core. Hence the secondary's o/p voltage is adjustable. The diddy therapy apparatus on the right works on the same principal.
I've only just been given this item, & yet to carefully test it & power it up. The "Schulmeister" is in great nick. Back in the early 70's, I used to get my classes of RAF apprentices to hold hands & form a circle & it could feed about 15 of them off a 9V battery. Happy days. Regards, David |
#9 | |
![]() Quote:
The product diversity of this company also embraces the low-tech.
-- Graham. G3ZVT |
#10 |
Might it've been the prime-mover for a small spark transmitter?
#11 |
Well - it jolly well works ! Connected my DC PSU set at 4V, it drew approx. 160mA through the primary. An AVO 8 indicated approx. 30V of fundamental rough AC from the secondary. However, it scoped, using a x8 probe, about 1200V P - P spikes. The Time/Div indicated a freq. alternating between 25 & 50 Hz. This was due to the thread being pretty phooked on the spark-gap adjustment screw. A h/held freq. counter also roughly indicated similar frequencies. Inserting the chromed brass tube, thus shielding the iron core, reduces the sec. o/p to nothing.
I'm guessing this is the oldest piece of antique electronics I've ever worked on. Less than half the size of the "Schulmeister", which is of a similar age, but in pristine nick. Regards, David |
#12 | |
![]() Quote:
Paul |
