#21 |
In this case I think the original code memory device is a mask programmed ROM, so not subject to bit-rot in the same way as EPROMs. The data read out will probably be right every time or wrong every time, if there has been a failure of one or more bits.
#22 |
The Introkit+KITBUG 'talked Teletype'. So I think looking at KITBUG source would provide pointers.
NS Germany might have reused code. (I can't find a listing at this moment! Will there be an ASCII lookup table?) Obviously the TELEKIT monitor (what do we call it?) is also scanning the (unique to 6025 calculator) keypad matrix and LEDs. Not sure what it will be outputting to the display.
x^4 + x^2 + y^2 = 0 |
#23 |
Although we can see it does the full alphabet, it could work fully with just 20 keys... just the necessary characters for Kitbug, which is
0-9, A-F, T for type, M for modify and G for go, and an 'enter' (ascii CR) key. I did a serial hexpad like this for my 6800 and Rc2014... (Arduino) but that was send-only, the Telekit would need to also convert incoming async ascii to a 7-seg 'Message' type display... (do I feel a 'Telekit-repro' project coming on...? ![]() Last edited by Phil__G; 24th Sep 2023 at 11:11 am. |
#24 |
The KITBUG listing is in Appendix B of the user manual
http://www.bitsavers.org/components/...nual_Mar76.pdf |
#25 |
I've sent an edit to previous post:-
CuriousMarc has the Introkit User Manual in his Documentation Cache and that is where the KITBUG listing can be found. I'm looking at that now. I have found another NS calculator, the 4515 'Mathematician, that has the same keypad layout as the 6025 so they might have the same contact matrix inside the keypad subassembly. It would be helpful to know the matrix layout. Or the calculator IC. Around 1975 NS were pioneering the 'black blob' technique ("COB") of mounting the IC dies directly to the back of the LED display. Some of the calculators I've seen in this group don't have much inside the case. Presumably later in production. Yes, TELEKIT can send alphanumerics into the LCDS so I'm expecting a table to convert keymatrix-byte to ASCII-code. And it will be interesting to see how TELEKIT is set up to display (on 7seg displays) whatever's received from the LCDS.
#26 |
I believe I've located the calculator IC in a 1977 Nat Semi databook.
So keyboard matrix is 4x9. The PR versions of those calculators have the extra slide switch. There is a companion IC that adds the program storage option. 6025 & TELEKIT pics give matrix positions of TELEKIT keys.
x^4 + x^2 + y^2 = 0 Last edited by circuitryboy; 24th Sep 2023 at 1:36 pm. Reason: More data |
#27 |
Transmit is easy peasy but 7-seg lookup, scrolling and multiplexing is quite busy, so I'm guessing receive is interrupt driven...
although Kitbug is full duplex and sends concurrently as it receives (bit by bit, unlike a uart), so transmit cant be upset by receive & vv I think the way I'd approach it is to have a timeout on the start bit detection, since all kitbug output is contiguous, a pause means its finished sending and we can have 100% cpu for the display routine, which would only have to test SA for a start-bit edge, just a few cycles so v quick... .... or another way would be to tailor the display scan to 4.5ms (maybe faster scans but more of them) so the display routine can be used for the 110 baud delays... If its a big disassembly job, why dont we do a bit each? . Last edited by Phil__G; 24th Sep 2023 at 1:45 pm. |
#28 |
Post #16 shows uv eprom, with no label on the glass window, though it probably spent all its life inside the calculator case.
#29 |
I confess I had assumed that all of the MM5 series memories were mask programmed devices. School day every day, etc.
#30 |
The ETI article is particularly revealing:
#31 |
Ah wow I had read that but, at the time had not seen a Telekit so never made the connection - nice find.
For those interested the PROM SIMULATOR PLUG he talks about in the last paragraph is the seed of the idea for the SCRUMPI 1... which is why I know the article. |
#32 |
Well I’m shocked. I found that ETI article when I was trawling the net for anything LCDS related but never read past the 1st page. Thanks Phil, that’s going to be a great help in debugging the TELEKIt.
#33 |
Same here except I was actually searching for TELEKIT and still didn’t realise there was a block diagram included.
#34 |
Is it just me? I've been reading that second ETI page since it was in post #1, but I find the text in Fig.s 1 & 2
only 50% legible so didn't look for very long. Of course it's exactly as given on Worldradiohistory. I no longer have my hoard of old magazines. Does anyone have those pages on the original paper? And it's only now filtering through to me: the TELEKIT will interface with anything that's expecting a teletype? (With whatever limitations 9x[7-seg digit] will present.)
#35 |
Here at last is the TELEKIT source. Added some initial comments but please don't take them as gospel. Feel free to update with additional comments / insights and post back (with a revised version number in the filename).
A few things from inspecting the TELEKIT PCB:
#36 |
Thats interesting, I'd always assumed in ignorance that the LCDS ran Kitbug.
250 baud is well weird, has the crystal been changed? I need to do some reading ![]() "CL 0001" ? I wonder if somewhere in all the invalid instructions from 1F0 to 1FF theres a 7-seg translation table? it would be quite long to cover A-Z, 0-9, symbols etc 1FF minus 1D0 is 47 (decimal) entries so could be... Last edited by Phil__G; 26th Sep 2023 at 1:25 pm. |
#37 |
Yea that dawned on me as well about general teletype - sounds useful.
I will hopefully be able to do a better scan of the pages on the weekend as I have a copy on the way... I had been looking out for one for a while due to the proto SCRUMPI mention. Anxious to see the ROM contents now for the character set and a disassembly - will be fascinating. (EDIT: crossed with post with source... oh nice - there must be a segment table in there) For those looking out for a Financier PR there seems to be (the one I bought) a version with some of the keys marked - the numbers correspond but, may have to do some fiddling with the others... This sounds like a great project to include one of Karen's PIC based SC/MP units in... at least until (hopefully) we can clone the PCB... Last edited by Timbucus; 26th Sep 2023 at 1:32 pm. Reason: spotted cross post |
#38 |
Ok as suspected, I've found the characters in 7-seg
Just drawing it up now |
#39 |
Ah you beat me too it... just understanding the rest of the code
#40 |
![]() Code:
; seven-segment display table. ASCII is used as an offset into the table from 0x01A0h ; byte at that offset is true (noninv) 7seg for the character ; eg ascii "H" is 0x48, 0x01A0 + 0x48 = 0x1E8, byte at that address is 6E, binary 01101110, segments bcefg = "H" : ; segments oranised a b c d e f g dp ; bit 7 6 5 4 3 2 1 0 ; ; aaaaa ; f b ; ggggg ; e c ; ddddd dp ; 01C0 00 ; start of ascii to 7-seg table and ascii 20h = space 01C1 41 ; "'." hex 21 exclamation 01C2 44 ; "||" hex 22 quote marks 01C3 01 ; decimal point hex 23 01C4 01 ; decimal point hex 24 01C5 01 ; decimal point hex 25 01C6 01 ; decimal point hex 26 01C7 40 ; "'" hex 27 01C8 9C ; "[" hex 28 01C9 F0 ; "]" hex 29 01CA 01 ; decimal point hex 2A 01CB 01 ; decimal point hex 2B 01CC 01 ; decimal point hex 2C 01CD 02 "-" hex 2D 01CE 01 ; decimal point hex 2E 01CF 01 ; decimal point hex 2F 01D0 FC ; "0" hex 30 01D1 60 ; "1" hex 31 etc... 01D2 DA ; "2" 01D3 F2 ; "3" 01D4 66 ; "4" 01D5 B6 ; "5" 01D6 BE ; "6" 01D7 E0 ; "7" 01D8 FE ; "8" 01D9 F6 ; "9" 01DA 01 ; decimal point 01DB 01 ; decimal point 01DC 01 ; decimal point 01DD 12 ; "=" 01DE 01 ; decimal point 01DF CB ; "?" 01E0 FB ; "@" 01E1 EE ; "a" ascii 41h 01E2 3E ; "b" 01E3 1A ; "c" 01E4 7A ; "d" 01E5 9E ; "e" 01E6 8E ; "f" 01E7 BC ; "g" 01E8 6E ; "h" 01E9 20 ; "i" 01EA 78 ; "j" 01EB 4F ; "k" 01EC 1C ; "L" 01ED EC ; "M" (approximated) 01EE 2A ; "n" 01EF 3A ; "o" 01F0 CE ; "P" 01F1 3B ; "q" (actually o. ) 01F2 0A ; "r" 01F3 B7 ; "s" 01F4 0E ; "t" 01F5 39 ; "u." 01F6 38 ; "v" 01F7 7E ; "W" (cap A inverted) 01F8 28 ; "x" ( || ) 01F9 76 ; "y" 01FA 92 ; "z" (3 horiz lines) 01FB 00 ; " " space or end of 7-segment table 01FC 00 ; " " space 01FD 00 ; " " space 01FE 00 ; " " space 01FF 00 ; " " space Go for it Tim, many hands make light work... ![]() . Last edited by Phil__G; 26th Sep 2023 at 2:56 pm. |
