Old 31st Aug 2023, 2:48 pm   #1
TimothyStuart
Default HMV 2340 low AC Voltage Operation Problem
I have just finished renovating the amp/tuner from an HMV 2340 radiogram. It had suffered a major eletrical incident including exploded capactors and not been used for over 20 years. I have replaced all the pre-amp and output transistors and most of the resistors, all the capacitors as well as the bridge rectifier. DC voltage checks are very close to the HMV circuit diagram.
It now operates but if I put 80V AC through it from my variac it sounds okay and then increasing the variac to 165V the sound quality remains unchanged. Anything over 165V and the sound distorts badly. I wonder if anybody has experienced anything similar with this unit as I am struggling to solve the problem. Thank you.
TimothyStuart is offline   Reply With Quote
Old 31st Aug 2023, 9:42 pm   #2
ben
ben's Avatar
Default Re: HMV 2340 low AC Voltage Operation Problem
Sounds like the o/p stage is still faulty. Check the biasing and voltages. Are both channels the same? What transistors does it use?
Ben.
Old 1st Sep 2023, 8:56 am   #3
TimothyStuart
Hi Ben. The main output transistors are AD161 and AD162. I did replace them.
Both channels are the same. Thanks Tim
Old 1st Sep 2023, 11:17 am   #4
SteveCG
I'm not familiar with this model, but it is curious that the sound on both channels is alright at low mains voltage but deteriorates above a 165 volts.
As ben says the first thing to establish is whether the output transistor biasing is roughly correct. If these transistors are being biased on heavily then they will get hot. Can you safely feel them, with no signal input? They should be cool and remain cool under these no-signal conditions. If they are hot then turn off quickly and follow any advice on setting the bias given by the manufacturers. I would guess it will be in the region of 20 milliamps.
SteveCG is offline   Reply With Quote
Old 1st Sep 2023, 2:46 pm   #5
TimothyStuart
Thank you Steve. The output transistors are all running cool under no signal conditions and when up to 165V is being used. I have not run the unit on 240V for any length of time as clearly there is a something amiss at this voltage.
As a novice should I be checking the output transistor's resistors? I replaced them following the spec on the service manual. How critical is the wattage for these resistors please? I used a .5W. There is no value given for these resistor's wattage in the service manual. You mentioned a measurement of 20 millamps. Where should this 20 milliamps be measured please?
Old 1st Sep 2023, 7:00 pm   #6
Ed_Dinning
Hi Tim, I think you need to be checking DC voltages around the output stages
Ed
Old 2nd Sep 2023, 10:10 am   #7
SteveCG
TimothyStuart:
The 20 milliamps would be measured in the collector lead of one of the output transistors - your service info should say exactly where. However, if you have a digital voltmeter which can read DC millivolts then a way I use myself is to simply measure the voltage across one of the emitter resistors in the output transistor pair and applying Ohm's law, work out the current that way. For amplifiers where originality/least hacking about, is a goal it saves cutting into the leads.
As for the wattage of the resistors, I think I would be using a higher wattage whose value depends upon resistance and the currents you expect to be flowing through them; without more info on the amplifier I can't say further. One thing though is that the problem you have (distortion above 165 V) would not be caused by a correct resistor value but too low a wattage. The problem you get with too low a wattage is that the resistor would burn out though prolonged use at high out levels - and you have not got to that stage yet!
Thinking on the fault you describe further, do the amplifiers use an AC128 transistor in the driver stages? These can develop a fault known as 'tin-whisker syndrome'. This can cause all sorts of problems if the transistors are mounted on the amplifier chassis.
See this thread for more info.
https://www.vintage-radio.net/forum/...d.php?t=201719
Old 2nd Sep 2023, 9:46 pm   #8
Michael Maurice
Michael Maurice's Avatar
Originally Posted by SteveCG View Post
TimothyStuart:
But i wouldn't expect it to cause distortion on both channels! Besides if they were faulty it would show up at any setting of the variac.
The original bridge rectifier was selenium, the one you fitted is almost certainly silicon which has a lower forward drop voltage and thus you get a higher HT,
Forum Moderator
Michael Maurice is offline   Reply With Quote
Old 2nd Sep 2023, 10:16 pm   #9
Jez1234
If the OP has a schematic they could put up here it would make it rather easier for us to help.
Jez1234 is offline   Reply With Quote
Old 3rd Sep 2023, 9:05 pm   #10
Michael Maurice
The circuit diagram is available from this site.
The mains transformer is designed to give 22V which when rectified by a selenium rectifier will give around 25V, however you have almost certainly replaced it with a silicon type in which the DC output is 1.414 of the ac into it which is 31V.
That is around 22% higher than the circuit is designed for.
You may be best fitting the original rectifier and seeing what happens.
Forum Moderator
Old 4th Sep 2023, 2:32 pm   #11
It'll be less than 1.414*AC voltage in, you need to take into account the load current and the forward voltage drop across the diodes.
ms660 is offline   Reply With Quote
Old 4th Sep 2023, 3:30 pm   #12
peter_sol
Hello.
I have had the same problem turning up the variac.
It is possible that if you go past the point where you get distortion it will get better.
Best to monitor the centre point of the output stage which should be just under half the supply voltage.
Quoted as 10.7v for 25v HT.
Also note that the voltage regulator VT9 is common to both channels (and its associated components)
peter_sol is offline   Reply With Quote
Old 7th Sep 2023, 8:20 am   #13
TimothyStuart
Thank you all for your help. Yes one AC128 tr is used but I replaced it as it tested below spec. I will try to source an original bridge rectifier as your assumptions are correct with the new silicon BR I have used. If I manage to solve the problem I will report back.
Old 7th Sep 2023, 3:09 pm   #14
Jez1234
You can simply fit a suitable wirewound resistor to replicate the forward resistance of the selenium rectifier and thereby get the correct voltage plus the greater reliability of a silicon rectifier.
Old 22nd Sep 2023, 4:10 pm   #15
TimothyStuart
I have found out that D10 - which is a 15V zener diode - is faulty. The original should be either a BZX19 or BZX10. The diode removed reads TI 2150 A so I am not sure what replacement diode I should fit? I do not think I can get any BZX diodes (NOS) so will any 15V zener be a suitable replacement? What about the wattage value?
Thanks for your help.
Old 22nd Sep 2023, 4:59 pm   #16
Jez1234
Any 15V 500mW Zener should do the trick.
Old 23rd Sep 2023, 5:53 pm   #17
TimothyStuart
Thank you Jez
