26th Jul 2020, 1:54 pm | #1 |
Binatone Commando successful repair
Quite some time ago I posted about this pocket radio. I finally got around to successfully repairing/ modifying it. The RF stages were all fine but there were three unmarked AF transistors which appeared to be problematic. I decided to use a TDA2822 chip instead. I have used just one channel of the stereo IC and the radio is quite loud. Pictures attached.
Thanks to everyone for the earlier pictures and ideas. |
26th Jul 2020, 2:54 pm | #2 |
Re: Binatone Commando successful repair
Bearing in mind the state it was in when you got it I think you've done well, there's nothing wrong with an honest "get it going" repair or modification.
T
Adapt, Improvise, Oh Bother..... |
26th Jul 2020, 3:48 pm | #3 |
Thanks. Looking at the history of this radio, it seems to have been made around 1970. 50 years is quite a long time for this average build radio to have survived. Fitting the IC with all those bulky electrolytic caps in a tight space was tricky, but fun.
28th Jul 2020, 4:00 pm | #4 | |
The Branding "Binitone" doesn't instill too much confidence. It's amazing that someone would invest the time to repair it, but that's the spirit of collecting. As usuall, Dave USradcoll1. |
28th Jul 2020, 9:48 pm | #5 |
I think these were sold under a few different brands, the were the Harvard Cadet in their range of military themes radios.
29th Jul 2020, 1:26 am | #6 |
I had one when I was a kid, probably about 1975-6. Wasn't badged Binatone, I think it was something-Sonic.
Regards, Paul
...No, it's not supposed to pick up the World Service, it's not a radio! |
29th Jul 2020, 12:37 pm | #7 |
I bought this when on holiday in Jersey Channel Islands in the mid seventies from a novelty shop and still use it as it still works ok, quite good audio for a small speaker. Minor wiring repairs and a battery box was all it needed to keep it going. The Varta cells seem to be much better than Duracells.
Geoff |
29th Jul 2020, 1:26 pm | #8 | |
https://www.youthkiawaaz.com/2019/11...-khas-village/
Kevin |
29th Jul 2020, 10:20 pm | #9 |
http://www.vintage-radio.com/manufac...t-trannie.html
This has a few other military themed radios if you scroll down.
29th Jul 2020, 10:48 pm | #10 |
Used to repair those at Makro.
One of the lads had one on his bench which refused to be repaired. After spending an hour and replacing dozens of components, he took it out to the car park, and after kicking it from one end to the other, he filled in a return to manufacturer form stating it was very intermittent on FM, pleas advise. |
30th Jul 2020, 6:35 pm | #11 |
It seems that yours is the 3 volt version, with driver and output transformers as opposed to my 9 volt version using a preamplifier transistor and two transistors in push-pull configuration.
30th Jul 2020, 7:17 pm | #12 |
I wonder how often people lost the original twin battery box and connected a 9V rectangular battery to the clip?
1st Aug 2020, 6:16 pm | #13 | ||
2nd Aug 2020, 9:59 am | #14 | ||
Geoff |
2nd Aug 2020, 11:08 am | #15 | |
At their peak they badged quite a diverse range of products, from Portable TVs, simple 'pong' type video game consoles, clock-radios, wired phones, analogue cordless phones and several CB radios. The Binatone name was therefore not really much of a guide to the quality of what was inside, although they tended to go to the low to medium end. At least two of their CB radios had decent Japanese-made innards, although the same Japanese chassis was found inside at least a dozen other-branded radios. Last edited by SiriusHardware; 2nd Aug 2020 at 11:25 am. |
2nd Aug 2020, 3:48 pm | #16 |
The Binatone TV set I had was made in Hong Kong in 1983, & probably used a chassis used in sets with many different brandings.
I've noticed the Binatone 12" black and white sets seemed to vary a fair bit, as if they switched supplier a few times.
