11th Mar 2020, 3:44 pm | #61 |
Re: Damaged vintage variac
The attached is lifted from a Variac (Lyons/Zenith) manual.
Alan |
11th Mar 2020, 7:55 pm | #62 |
But don't use carbontetrachloride as it is carcenogenic.
Some years ago I visited Saudi to train some technicians for our agent and needed to clean flux off a pcb. I was given Carbontetrachoride. When I pointed out it was carcenogenic and he should be using something like IPA I was told that this was unobtainable as it was alcohol and all alcohol was banned! Peter |
11th Mar 2020, 8:31 pm | #63 |
I'd assumed that neither crocus paper nor carbon tetrachloride would be readily available. I used already worn P1600 carbide paper and meths on mine. Seems to have survived ok.
Alan |
11th Mar 2020, 9:55 pm | #64 |
If this is a Variac then the track is likely to be plated with noble metals such as hard gold alloy. Therefore be very careful not to rub it out.
If you do go through to the copper then it should still work but wear and corrosion will be worse. White spirit would be a better solvent than IPA for petroleum contamination. Carbon tet was used to clean clothes with oily stains. If the knob will come off, I would leave the set scews and drill and tap for another set screw. |
12th Mar 2020, 11:37 am | #65 |
Just as an aside, I have an ancient Variac which kept seizing up if it wasn't used for a while and kept in the cellar. It turned out that the shaft is made from something akin to Bakelite. It was a snug fit into the brass top and bottom frames, and used to swell ever so slightly. I learned from this forum that bakelite and its ilk is 'organic' and hygroscopic. I've had a similar thing with old bayonet lamp adaptors stuck in the holders. Easing the holes slightly with a rotating 'flapper wheel' has sorted it (for now). Cheers, Pete.
12th Mar 2020, 11:57 am | #66 | |
Many years ago when I was young and naive I worked in a lab in a basement. I had a colleague with an old motor bike. We had a few beers at lunch time and then the colleague spent the afternoon cleaning the grease from his motor bike in the lab using a gallon bottle of carbon tetrachloride. At the time I don't think the health risks were known. It was only afterwards that we heard of health warnings. Luckily it doesn't seem to have done us any harm.
Stuart The golden age is always yesterday - Asa Briggs |
12th Mar 2020, 1:51 pm | #67 | ||||||
Wow! Lots of useful info here!
12th Mar 2020, 2:49 pm | #68 |
I'm not sure whether or not crocus paper/cloth is available these days but it was made using jeweller's rouge, in other words ferric oxide (rust). Ferric oxide is a very mild abrasive and Lyons/Zenith were obviously keen to stress that nothing more aggressive should be used for track cleaning. I used (very gently) P1600 carbide paper because I happened to have some which was already well worn. Silicon carbide is a very hard and sharp abrasive so if you decide to use carbide paper go for the finest grade you can and wear it down beforehand.
Alan |
12th Mar 2020, 5:19 pm | #69 |
An ink eraser is often effective for removing oxidation from sliding contact surfaces such as sliprings and commutators. It may be worth a try, especially if the Variac track is plated. Then a clean with a stiff toothbrush and a wipe with a little meths on a rag should do the trick. Don't let the brush get wet.
Leon. |
13th Mar 2020, 12:29 pm | #70 |
I think the main danger with carbon tet is if you happen to be a smoker.
I think COCl2 (carbonyl chloride) is the toxic result. Les. |
13th Mar 2020, 1:08 pm | #71 |
Finely divided hot carbon (i.e. glowing cigarette butt!) can be an effective catalyst/facilitator for many reactions- I'm sure there is a documented case where someone actually died as a result of carbonyl chloride (phosgene) poisoning resulting from something like using carbon tet whilst smoking. There was also a rumour in the company I worked for (from before I joined) that someone had become very ill from using Colclene TF (a long-banned CFC-rich cleaner) whilst smoking.
13th Mar 2020, 4:28 pm | #72 | |
In the circumstance and with TrevorG3VLF mentioning that there might be a noble metal coating present, I was very nervous about using anything abrasive and I am glad that I didn't. Not having anything remotely close to crocus paper to hand, I tried some metal polish wadding that I had on hand in the shed and was pleased to find that this worked a treat! The dark crud/oxide came off with moderate effort and did indeed reveal a silver metal coating on top of the copper. This does have some tiny scratches and slight pitting in places but overall, the track looks to be in reasonably good condition. Having cleaned with the metal cleaner, I then wiped down and cleaned again with white spirit. I now get consistent resistances across the entire winding. Is it best to put a slight film of grease on the track during re-assembly? I am just cleaning up the brass coil mountings after which I will be almost ready to start re-assembly. I just need to fix the small bit that broke off the insulator cylinder during dismantling. |
13th Mar 2020, 4:47 pm | #73 |
I certainly wouldn't put any grease on it, the carbon contact should be enough.
13th Mar 2020, 7:03 pm | #74 |
Definitely no grease. Resistance measurements are not accurate in this application as there is a significant breakdown voltage associated with carbon brush contacts. Having cleaned the track, swing the brush from end to end about a dozen times with no applied voltage. Don't then clean the track again - you need a graphite deposit on the track.
Finally, test on a light load first, possibly monitoring voltage drop between the brush and track using a fine probe. A full load test should result in only a little brush heating. Over-cleaning a well run in slip ring, track or commutator is a mistake. I hope a full load test goes well. I have an identical Variac which runs cool at its rated 8A load. These were built to last, but damp storage will swell the phenolic core shaft and cause seizure. Leon. |
13th Mar 2020, 8:49 pm | #75 | |
You need a high-ish speed electric drill or dremel and some emery cloth (not emery PAPER) Get a length of rod which will fit in the chuck and is smaller than the bore you intend to polish. Cut a slot with a hacksaw straight down the centre of the rod, starting on the far end, to a depth of maybe an inch. So your rod ends in a pair of half-cylinders with a sawn gap between them. Tear off a 1 inch strip of emery cloth and fit one end of it through the slot. Oriented so that when the drill spins, the emery cloth is left behind like a rotary whip, gritty side out. You're not trying to make a hard cylinder of emery, the flexible whip nature makes it follow the bore you insert it into, the abrasive is centrifuged outwards into contact with the bore and it does gentle honing. It also follows round shapes naturally and doesn't try to dig in in places like a hand-held rotary stone does. Used to use long rods when decokeing cylinder heads to get into those hard to reach places. David
14th Mar 2020, 9:22 am | #76 | |||
14th Mar 2020, 11:54 am | #77 | |
In normal use in a dry workshop the most it will ever need is going over with a dry brush every 10 years or so. Anything oil based will make it get clogged up with dust. Once the shaft turns reasonably easily there should be no need to open out the shaft hole any more. It should stay free if it is used often enough. |
14th Mar 2020, 11:56 am | #78 |
I would avoid pencil derived graphite as it is mixed with binders such as clay which can be abrasive. Further, its resistivity and adherent properties when lodged between the turns are not characterised. Just run the specified brush over the track - Zenith will have done the development work.
From my work in the automotive sector, I have observed that brush selection is as much an art as a science, and a Variac must be critical in this, as current density is high and the characterisation of directional resistivity is important. The actual manufacture of carbon brushes is also an art, as Morganite found when they moved from Battersea to S Wales. As many of the old hands refused to move they had some real problems. Such is the value of expertise. Leon. Last edited by Leon Crampin; 14th Mar 2020 at 12:11 pm. |
14th Mar 2020, 12:24 pm | #79 | ||
That's a fair point. I guess any such clogging could possibly develop unpredictable conducting characteristics (similar to what was mentioned by Leon in the next post) so it makes sense that anything oil based is best avoided.
14th Mar 2020, 5:46 pm | #80 |
The bending of the bottom frame may have misaligned the bush in it. Along with the close fit, that may be enough to stop the shaft from rotating. Fixing the bend might be enough to restore normal operation
