Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Old 8th Jan 2019, 6:45 pm   #1
Sandycat
Default 50Hz Motor Pulley for Collaro
Hi All,
I'm a Brit living in Fort Wayne, home of Magnavox, but possibly returning to Europe soon. I have a number of '58-61 Magnavox consoles which I'd like to haul back, all with Conquest 600 or 400 tables.
I think I will need to replace the motor pulleys to accommodate the power supply frequency change - is there a place that sells them can anyone advise?
Thanks,
Rob
Sandycat is offline
Old 9th Jan 2019, 12:56 am   #2
Alan SP15
Default Re: 50Hz Motor Pulley for Collaro
Sadly no. You will probably have to find 50c/s decks and use them for parts. Collaro had a strange range of pulleys (usually 6, colour coded) to accommodate variation in the manufacturing. Advice in the service info being to contact their service department if the speed was unacceptable, giving the colour of the fitted pulley and they (Collaro) would send the next size, up or down depending on the fault.
This seemed to apply across the range of changers/single players and what I term the 'heavies', ie 2010 (3 speed) and 4T(R)200 models, types that used the Collaro 'push on' pulleys. Pic of a typical 4 speed pulley.
Alan
Alan SP15 is offline
Old 9th Jan 2019, 5:02 am   #3
Boater Sam
Simply sleeve the small pulley/spindle to increase the speed of the driven part by 20%.
Its easy going this way, going from a 50Hz deck to work on 60Hz is tough because usually you cannot reduce the size enough.
Boater Sam is offline
Copyright ©2002 - 2019, Paul Stenning.
