Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Wanted (private buyers only, no swaps)
Sets, Parts and Service Information Wanted (private buyers only, no swaps) If you need help obtaining components, sets or equipment, post a message here. Private buyers only - no traders. No swaps.
Old 8th Jan 2019, 5:51 pm   #1
recordplayer
recordplayer's Avatar
Default Transistors for Clarke and Smith CS1 record player
Hi.
Does anyone have any MP8112 and MP8512 transistors - 2 of each if possible. These are small flat type transistors used in a Clarke and Smith record player for the output transistors. The MP 8112 is the culprit it reads leaky/faulty.
recordplayer is offline
Old 9th Jan 2019, 8:03 pm   #2
recordplayer
Default Transistors for Clarke and Smith record player by
Hi , regarding an earlier post of mine - please see pictures of the MP 8112 and MP 8512 output transistors that I need for this Clarke and Smith CS 1 record player - they are the unusual black transistors mounted on the heatsink at top of pic , thanks Tony .
ID:	176187   Click image for larger version
Old 9th Jan 2019, 8:38 pm   #3
AC/HL
AC/HL's Avatar
Default Re: Transistors for Clarke and Smith CS1 record player
Available from Cricklewoods
https://www.cricklewoodelectronics.com/MP8112.html
https://www.cricklewoodelectronics.com/MP8512.html
Bill, BVWS member
AC/HL is offline
Old 9th Jan 2019, 8:41 pm   #4
recordplayer
Thanks Bill.
Old 10th Jan 2019, 12:02 pm   #5
Herald1360
Herald1360's Avatar
Looks like the heatsink's drilled for TO3. You could just use something considerably beefier and easier to source than those 'orrible things I remember from Sinclair stuff.
The amp could end up bomb proof, too.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 10th Jan 2019, 3:18 pm   #6
boxdoctor
boxdoctor's Avatar
Motorola's car radio design department had a love affair with those in the '70s.
I changed loads of them. They seemed to be very unreliable.
Herald's suggestion is eminently sensible - plenty of tougher TO3 types (if that heatsink is drilled for TO3s) available at a fraction of the cost. Tony
The job "couldn't be done".
He didn't know that,
So he did it.
boxdoctor is offline
Old 10th Jan 2019, 3:52 pm   #7
paulsherwin
paulsherwin's Avatar
Couldn't you just bung in a BD139/BD140 pair?
paulsherwin is offline
Old 10th Jan 2019, 4:31 pm   #8
mhennessy
If the originals are germanium, I can't help wondering if the AD161/162 pair would fit. A bit smaller than TO3, but seems a bit more likely given current practice at the time.
mhennessy is offline
Old 10th Jan 2019, 4:37 pm   #9
paulsherwin
They are silicon.
Old 10th Jan 2019, 5:00 pm   #10
mhennessy
Yes, I've just found them in Towers. An actual paper copy
Prior to that, I'd only found anything MP**** in an old TVT book, and all of those listed were germanium. Looking at the machine, it does look contemporaneous with things like the Bush SRP51, for example, but then this is Clarke and Smith - looks can be deceptive!
Old 10th Jan 2019, 7:46 pm   #11
Maarten
If the heat sink is indeed drilled for TO-66, modern TO-220 replacements will fit perfectly (with the right insulator of course). If it's drilled for TO-3, you can use TO-3P or TO-247 transistors.
Maarten is offline
Old 10th Jan 2019, 9:04 pm   #12
AC/HL
AC/HL's Avatar
Or just replace the single failed transistor and keep it original. It's not a common or repeat fault. If that doesn't work, perhaps then go down the modification route.
Bill, BVWS member
AC/HL is offline
Old 11th Jan 2019, 12:48 am   #13
Restoration73
Restoration73's Avatar
The TO-66 2N3054 was quite common, and RS made a matching PNP3054. I doubt
whether these would be easily destroyed.
Restoration73 is offline
Old 11th Jan 2019, 8:52 pm   #14
recordplayer
Got the original transistors from Cricklewood Electronics - fitted them plus changed four electrolytics which where out of spec and speaker needed replacing - it was slightly grating - it was rescued for a rubbish tip !! It sounds great now and is really well made - will give it a good soak test and service the Garrard deck - lovely well made player .
Old 12th Jan 2019, 12:04 am   #15
Tim
Tim's Avatar
Oh THOSE things. They earned me plenty of pocket money when I was a lad, replacing them in record players and stereo's of the time. Ultra/BRC I think used them.
Tim is offline
