9th Jan 2018, 6:30 pm | #21 | |
Re: Size of an object not connected to safety physical earth, to be effective earth
You are right in saying that in SI electric charge has the dimensions s A In cgs electric charge has the dimensions g^0.5 cm^1.5 s^-1 It really does https://en.wikipedia.org/wiki/Gaussi...Unit_of_charge. They are not the same. Cheers, GJ
http://www.ampregen.com |
9th Jan 2018, 6:50 pm | #22 | |
I won't attempt equations - as you indicate, they don't come out well on the Forum. It would also lead us (almost but not quite) off-topic. Martin
BVWS Member |
9th Jan 2018, 6:59 pm | #23 | |
Cheers, GJ
9th Jan 2018, 10:38 pm | #24 |
Having just read the Wikipedia article on cgs as applied to electromagnetism I am glad that I never had to learn it or use it. What a mess!
PS Perhaps I should have said 'them' instead of "it" in the above sentence because it appears there are three or four cgs versions for electromagnetism. They differ in where the factors of c appear. Last edited by G8HQP Dave; 9th Jan 2018 at 10:42 pm. Reason: add PS |
9th Jan 2018, 10:39 pm | #25 |
Turning moment is measured in Newtons-metres (= kg.m2.s-2); which look a lot like Joules, dimensionally, but aren't. (Although, if the magnitude of the force remains constant, the turning moment is equal to the work done per radian of angle turned through.)
Otherwise, if anything else has dimensions kg.m2.s-2, it's probably energy.
9th Jan 2018, 11:18 pm | #26 | |
It was a bit annoying though because when I was studying this the most authoritative book on the whole subject https://en.wikipedia.org/wiki/Classi...dynamics_(book) was written using cgs units. Fortunately I only needed it occasionally. And now the latest edition at least starts in SI. Phew ! Cheers, GJ
10th Jan 2018, 12:13 pm | #27 |
My copy of Jackson is quite recent. I originally learnt EM from Landau and Lifschitz but I can't remember what units they used. I had enough trouble with particle physics, where c=h=1 is assumed but then the result of a calculation is expressed in MeV or millibarns!
10th Jan 2018, 1:35 pm | #28 |
Thank you , folks. There is much to digest here, very interesting stuff indeed. I am minded to do some basic experiments at some point in the (far from immediate!) future...
Al |
