Old 28th Dec 2019, 11:16 pm   #21
Dave Moll
Dave Moll's Avatar
Default Re: Belling 322 'Art Deco' electric heater
I don't know about a mica tube, but we had one with the elements in what was, I believe, described as a silica tube - some sort of heat-proof glass-like substance.
Dave Moll is online now
Old 29th Dec 2019, 12:39 am   #22
Refugee
Refugee's Avatar
They are indeed silica tubes with the elements inside.
I have got a "posh" one like the one linked to in post #20.
It also has the plastic logs with a light under them and the flame effect still works too.
We acquired it with the house.
Refugee is offline
Old 29th Dec 2019, 1:42 pm   #23
dave walsh
Yes Tanuki, we rarely ran ours with all three elements fired up! It was more Sci Fi than that one-just polished metal [no faux wood panels] and was wall mounted in the "front room" of our 'modern' [1958] newly built semi that it came with. The house had a ring main [explained to me by the electrician who brought his megger to locate a nail hammered through one of the cables]. Paraffin Lamps on the first night in residence The 3 bar fire had it's own cable to the fuse box, hard wired through a Storage Radiator type fused outlet! NO sockets were provided at all in what should have been our main living room OR the smallest bedroom. For a while we maintained the terraced house tradition of living in the back room with it's open fire, next to the kitchen [no concept of a Dining Room then]. Inevitably we wanted to be able to use the front part of the house in the end.
I was able to persuade my parents that I could tap into the fused supply for the fire [before the switch] and fitted a very neat socket along side. I did it very neatly because it would not have gone down so well otherwise! Based on this success and with advice from an electrical engineer my dad knew, I put 4 sockets into the un-wired bedroom. I removing the skirtings and there was space for wiring. Using an existing cavity [though the wall] into the back of a double socket in the main bedroom I was able to wire the sockets [in series] directly into the ring, without even having to use a junction box. It was a bit like invisible mending. I was 14 at the time and although 4 sockets seemed a lot for that small room, I somehow finished up with a bedroom/Radio Shack!
Dave W
Yes chaps I'm sure the tubes would be silica and not expensive mica. It was the first time that I ever came across a ring main, 13 amp plugs and hard wired electrical items ie the Fire and the Immersion. I remember the kudos gained by myself when the TV was in one room and the Record player in another. Happy Days!
dave walsh is offline
Old 29th Dec 2019, 2:38 pm   #24
Heatercathodeshort
Heatercathodeshort's Avatar
Trouser burners! J.
Heatercathodeshort is offline
Old 29th Dec 2019, 5:30 pm   #25
Red to black
Red to black's Avatar
Trouser burner! I like that true all the same though
Red to black is online now
